Old 12-27-2020, 03:03 PM   #1
Swedchevy67
PVC valve breathing
Trying to figure out how it’s fitting on my valve cover.
Need help on the fitting order.
When I removed the cover, I heard something
dropped inside the cover. When I took the
cover up, this parts was laying inside on
the top.
Swedchevy67 is offline   Reply With Quote
Old 12-27-2020, 03:11 PM   #2
truckster
truckster's Avatar
Re: PVC valve breathing
It's broken. I recommend you replace it.
If you decide to reuse it, the order would be housing, spring, weight, bottom cover. You'll need to figure out a way to glue the bottom cover on.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-27-2020, 03:20 PM   #3
Swedchevy67
[QUOTE=truckster;8855155]It's broken. I recommend you replace it.
Are you sure it’s broken?
Ok. Where can I get new one?
Old 12-27-2020, 04:20 PM   #4
RustyPile
RustyPile's Avatar
[quote=Swedchevy67;8855160]
Yes, it's definitely broken.. Positive Crankcase Ventilation (PCV) valves aren't normally disassembled for servicing.. Yours is worn out and has fallen apart.. PCV valves are cheap and available where ever automotive parts are sold... Bought locally from O'Reillys, NAPA, etc, they cost $4 - $5.. Bought on the internet the cost could double or triple..
RustyPile is offline   Reply With Quote
Old 12-27-2020, 04:28 PM   #5
Swedchevy67
[quote=RustyPile;8855190]
Appreciate your replies.
Old 12-27-2020, 05:02 PM   #6
geezer#99
geezer#99's Avatar
Looks a lot more like a spark arrestor than a pcv to me.
What hose was it attached to?
Old 12-27-2020, 05:14 PM   #7
Swedchevy67
If I remember right, it was attached to
the carburettor.
Yes you’re absolutely right. It is NOT
the PCV valve breathe.
Old 12-27-2020, 11:35 PM   #8
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
the carburettor.
It is a PCV! No doubt in my mind.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-28-2020, 03:08 AM   #9
Swedchevy67
Confused????
PCV or Spark arrestor. Same same but
different name?
I’m no mechanic, only a hobby enthusiast!
Old 12-28-2020, 10:27 AM   #10
geezer#99
geezer#99's Avatar
Easy to figure out.
Which valve cover was it on and where on the carb was the hose hooked to?
Pics help.
Old 12-28-2020, 02:36 PM   #11
RichardJ
Swedchevy67 has a '67 with inline 250.
If you have the original '67 Rochester B, there is no manifold Vacuum Port on the carb. The manifold vacuum port for the PCV is in the manifold, on the top of the 3-4 intake runner, behind the carb next to the head.
A spark arrester, if used, goes between the valve cover and the air cleaner. The arrestor is between the 2nd and 3rd hose clamps.
Forum pictures.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-29-2020, 01:23 AM   #12
RustyPile
RustyPile's Avatar
Forum pictures.
Referring to those same pictures.. Look at the second picture.. The PCV valve is attached to the end of the small hose going to the rear of the valve cover -- near the firewall..
Old 12-29-2020, 02:28 AM   #13
kwmech
Don't get all confused. It is a PCV valve
