#26 |
![]() Join Date: Jun 2016
Re: CS-144 140amp alternator upgrade howto
Is that a March bracket? That looks like an awesome solution.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#27 |
I manufacture the CS144 adapter bracket kit for guys running a GM serpentine setup-another option for everyone.
#28 |
OutOfMyMind & I'llNeverKnowWhy
Wow, its been awhile. I swapped over to a single serp belt setup off a Camaro and used a bracket for the cs-144 for awhile. But I no longer have the CS-144. I have an AD-244 now.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
#29 |
Nice!
#30 |
Digging this up as well. I have an 88 and looking to upgrade to a higher output. I was told a 94 Buick Roadmaster Alt but it did not fit so I sent it back to Amazon. I didn't know the bracket needed modified. What notch is it? How do I convert to a better Alt? Mine has the Serpentine setup on the alt only
My mother is a recent cancer survivor and this truck build is for her |
#31 |
This like has more info: CS-144 140amp alternator I hope this helps you. https://bowtieguy.proboards.com/thre...t-grade-cs144d
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#32 |
I ran the 144 alternator with pretty good success. I put in the Derale 16928 fans and they pull a LOT of power. I upgraded to a 170a single wire alternator from Summit. You can still use the CS plug for the dash light, but it no longer needs an exciter wire (load) to charge.
https://www.summitracing.com/parts/PWM-7864 I also increased the charge and ground wires. They are slightly larger than the starter cable. I don’t remember the exact size. At idle, the alternator wasn’t charging which can be a problem at long low RPM obstacles. I did some calculations with the charging RPM graphs and got a smaller puller (not by much) to have the alternator spin a little faster than stock. You HAVE to be aware of your top engine RPM and make sure the alternator spin speed does not reach its limit at the engines red line limit. My engine may hit 3500 OR 4000 RPM rarely, but that will spin the alternator at a max 8000 RPM, which is below the alternator’s red line. |
#33 |
Moderator
![]() Join Date: Oct 2008
Good point about paying attention to the redlines of the accessories when you change the pulley ratios.
Your rad fans shouldn't run much with the exception of stop and go traffic. You can probably get away with the stock CS144. 8ga or 10ga charge wire from the ALT BAT terminal to the starter BAT terminal will work just fine. If you're really pulling that much power you can get the four terminal AD244 from 2005 and earlier that doesn't require control from the PCM.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
