#51 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Picked up a GM 14 bolt rear end for the 63 C20
Yup, and that little purple(?) spring is the return spring for the adjuster lever.
#52 |
![]() Join Date: Jul 2015
Looks like the drums I have are too deep. Mine are 4.75” deep, from the face of the wheel mounting surface. And the rear end is 4.0”.
Anyone know what drums would be correct? Guess I gotta figure out what vehicles had a GM 14-bolt 8-lug rear end.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 12-25-2020 at 08:12 PM. |
#53 | |
Yours looks different than mine, but I checked it. It's from my '93. I'm pretty sure there is a light duty/heavy duty brake option though.
#54 |
Finally got it in. Found the correct drums too; 4-5/8” overall height.
And, the noise is gone! Drove it around the block and that horrific noise I had before is a thing of the past. However, I need to remove the trans, it’s leaking from the from someplace up front. Damn, thought it would be all good. Feels a bit easier to drive too, not geared so low. It’s 4:10, but much better than the 4:56. Had a difficult time bleeding the brakes again, got all the air out and didn’t have pedal pressure. After adjusting them, I got the pedal pressure back. However, it must be too tight, cause the truck doesn’t roll. If I get the truck to roll a little it just stops when I push the clutch in. I’m afraid if I ease up on the adjustment I will lose some of that pedal pressure. Also need to re-adjust the axle position. Don’t have and adjustable pan hard bar, so I’m contemplating cutting the weld on the bracket and getting it into position. It’s off by about an inch; not sure if it’s worth buying the adjustable pan hard bar from Brothers. Are they the only outfit to offer an adjustable pan hard bar?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 01-02-2021 at 07:37 PM. |
#55 | |
#56 |
Tweak the original pan hard bar?? That thing is so friggin heavy! How the heck?
1963 C20, small window, long bed 292, 4-speed |
#57 |
That one from POL needs a different bracket, I’m wondering if the one from Brothers just bolts right up to the stock mounts.
#58 |
Who Changed This?
You only need to back the brakes off a couple of clicks on the adjusters to get the friction reduced to where the truck will roll without resistance but still have a nice firm pedal. Play with it.
#59 |
What about the trans leak? Do these early transmissions have a seal on the input shaft? Is this probably where it’s leaking from?
#60 |
Yes - going to try this. Hope it works.
#61 | |
My initial inspection did not make me believe it is coming from the from shaft cover of the trans.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 01-03-2021 at 10:39 PM. |
