Old 01-02-2021, 10:27 PM   #1
Frugalmeyer
TCI Engineering’s 1963-1987 C10 Pro-Touring IFS
I am installing TCI Engineering’s 1963-1987 C10 Pro-Touring IFS on my 1972 and not sure how to best connect the steering shaft. The angle is a little sharp and as is the shaft would pass through at the corner of the TCI crossmember mount at the top of the frame. I do have a factory tilt column that I would like to keep.
Does anyone have the TCI kit installed and have pictures? Anyone have any ideas based on the attached photos?
Frugalmeyer is offline   Reply With Quote
Old 01-05-2021, 11:48 AM   #2
SCOTI
SCOTI's Avatar
Re: TCI Engineering’s 1963-1987 C10 Pro-Touring IFS
R&P swap set-ups usually require a shorter steering column for the best joint angles. I would make a call to TCI for their recommendation. Beyond that, you'll need to get creative & might need a 3-joint setup w/a brace to help reduce angles.
I took about 5-6" off of a vintage 67-72 auto tilt column in my 64 so I could get away w/using 2 joints @ decent angles (PB set-up w/R&P).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
