Old 01-05-2021, 04:18 PM   #851
TA_C10
TA_C10's Avatar
Re: 67 GMC super custom build
Thanks. I'm interested in this. Will be anxious to see end results with other side and what nozzle kit your using. Looks awesome.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 01-05-2021, 04:47 PM   #852
chewychevy67
This is actually all gm parts. The wiper arms are original 67, arm sprayer parts are 86 gmc, the other pieces under the cowl ifabbed from 80s truck pieces.
chewychevy67 is offline   Reply With Quote
Old 01-05-2021, 05:36 PM   #853
IronCanine
I'm trying....
IronCanine's Avatar
OMG...this thing is a GM Modzilla. Fog lights look great. I challenge you to make a SPID that reflects your creation.
IronCanine is offline   Reply With Quote
Old 01-05-2021, 06:37 PM   #854
chewychevy67
I'm not sure I could afford to have Jeff make me a spid lol. Here's the driver side. I'm also moving my washer hoses to the inside the cowl and using these clips from 60' gm cars to attach them inside and have them come out the lower Cowl to the washer jar. Just cleans them up completely.
Old 01-05-2021, 07:03 PM   #855
TA_C10
TA_C10's Avatar
I moved all my washer hoses inside the cowl as well, why they didn't do this from factory I dunno. Thanks for all your info on this, sweet mods!
"It's only money".
Old 01-05-2021, 11:46 PM   #856
chewychevy67
I think these have to go now too. They look out of place. Have to cut a piece out of another cowl to make it look like the rest.
Old 01-06-2021, 12:56 AM   #857
IronCanine
I'm trying....
IronCanine's Avatar
Best part about this...betcha 5 bucks this jewel never sees precipitation of any kind nor will the windshield collect any dust or detritus that is removed with the wiper blade.
...though she will be remarkably equipped for such action.
Honestly I think weather and/or bugs will just be too intimidated to try you.
Old 01-06-2021, 01:31 PM   #858
TA_C10
TA_C10's Avatar
"It's only money".
Old 01-06-2021, 06:10 PM   #859
chewychevy67
Oh I do plan on driving this truck. Not in winter or severe weather but bugs will hit it. I couldn't live with myself if I spent 15 years building it and another 15 looking at it. That wouldn't be much fun.
Old 01-07-2021, 01:05 AM   #860
IronCanine
I'm trying....
IronCanine's Avatar
Ahhh...I know you'll drive it...but it will be driven I'm sure with the same care and judgement with which it was constructed.
Old 01-09-2021, 11:57 AM   #861
chewychevy67
Got the proper 8 track mounting Brackets from member 3sondad and they are spot on. Real nice pieces. Much nicer than the pieces I had made for it myself. I had to modify the e brake cover slightly but won't be noticeable. I'm trying to get all the finishing touches done to the cab so I can get the metal work done. Hopefully by end of spring it will go for that!
Old 01-09-2021, 05:17 PM   #862
TA_C10
TA_C10's Avatar
"It's only money".
Old 01-21-2021, 12:14 AM   #863
chewychevy67
I wanted an under hood light but I don't like the ones that gm used in these years So I took some 54 caddy license lamps and I'm using the extra space in the hood. I am going to use 2, one on each side. It will still work on a Mercury switch but it will be hidden under the long support.
Old 01-24-2021, 09:38 PM   #864
chewychevy67
Well I got a cut out of a 72 cab door jamb where the jack spring screws in from my nephew and it happened to fit perfectly with the cover for the over of the sentinel photo cell so I'm thinking I may get this welded in to the dash top so it looks factory recessed like the vents are.
Old 01-24-2021, 10:54 PM   #865
Kronald_70GMC
Kronald_70GMC's Avatar
You are welcome! Glad it was of use to you as I would have probably thrown it out. Going to look perfect 👌
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 01-27-2021, 09:33 PM   #866
chewychevy67
Tonight I got the transmission oil cooler finished up and all the holes in the rad support for the fog lamps and oil cooler lines. I'm very pleased with how stock this looks. Both ac condensor and oil cooler are mounted with rubber well nuts like they started doing in the 70s. Not sure why but I'm assuming less vibration on these parts.
Old 02-05-2021, 10:26 PM   #867
chewychevy67
Instead of welding it in I bought a dimple die and pressed it into my dash. Now it will appear original.
Old 02-05-2021, 11:20 PM   #868
clay68c10
clay68c10's Avatar
Slick! Those dies are a neat tool.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-06-2021, 11:35 AM   #869
TA_C10
TA_C10's Avatar
Did the oil cooler brackets come with kit or did you make those? Slick.
"It's only money".
Old 02-06-2021, 06:16 PM   #870
chewychevy67
This isn't a kit . The cooler is from 70 71 chrysler cars and the brackets I had fabbed up. It's one of the mopar corvette style pieces and was expensive and hard to find.i really reached to find something period correct to keep it looking original that mounted on with tabs and had thread fittings rather than just generic. http://www.restorationradiators.com/...HTC%2D7071E71B
Old 02-06-2021, 11:18 PM   #871
chewychevy67
Both lights in the hood!
Old 02-07-2021, 01:33 PM   #872
TA_C10
TA_C10's Avatar
Those lights are fantastic, your making me think before I paint my hood...
"It's only money".
Old 02-07-2021, 10:23 PM   #873
chewychevy67
Lights on. This should provide lots of light under the hood.
Old 02-10-2021, 10:26 PM   #874
chewychevy67
I removed a brace from another hood and modified it to fit in the center for an added center brace. Also wired the hood lights so they disconnect easily and no wiring to be seen. The Mercury sensor is mounted inside the front of the hood next to the light.
Old 04-02-2021, 07:06 PM   #875
chewychevy67
I had fibernew refinish my original bright red door panels (they didn't do under where the insert goes) and they did my tissue box to match the darker vinyl in the seat center, dash pad and the rug. Turned out very nicely. Now if only sms was a little faster at getting my door panel inserts back these would be finished .
