Old 01-02-2021, 11:33 AM   #1
Reno
Reno's Avatar
LT4 Upgrade
Well I went and purchased a wrecked 2018 ZR1 SuperCharged Camaro with 10 speed automatic for my project upgrade......
I'm posting here as there are more C10's then my 1970 2WD Blazer and they are similar enough to get feedback.
Checking to see who has installed a Supercharged LT4 in their truck to learn from their experiences.
I do not want to purchase a new frame as I believe there should be enough vendors with upgrades to bolt on.....
The 2WD Blazer has factory trailing arms and should be upgrades for these as well...
I want a static suspension and not airbags.
SO with this information I'm open to suggestions..
Reno is offline   Reply With Quote
Old 01-02-2021, 12:40 PM   #2
REDROCKER652002
Re: LT4 Upgrade
Sell it to me, better yet give it to me. Hey, that's a suggestion. Just kidding Good luck with it. I am trying to convince me son to go that way with his 69 C10, but he is all about original. Until the stereo. LOL
REDROCKER652002 is offline   Reply With Quote
Old 01-02-2021, 08:25 PM   #3
gmc684x4
Re: LT4 Upgrade
Ls is the wsy to go unless you have a new 350 in the shop
I have to say where are the pics of the car and the truck your going to build ?
Many guys have used non turbo camaro exhaust manafolds with no fitment issues
I am going western chassis 2.5 drop spindle with 1 inch drop spring and either a 4 or 5 in the rear
The ece kits used western chassis and they are one of the original drop spindle manufacturers
I would avoid the slider style swap mount plates
I am looking at the ic billet 4 postion swap plates and the transdapt adapters as well as might try lsnova71 how he built his own from the truck mounts
gmc684x4 is offline   Reply With Quote
Old 01-02-2021, 08:29 PM   #4
gmc684x4
Re: LT4 Upgrade
Here is vette works weld on fuel pump ring to resuse stock fuel pump
I am not sure if a stock late model camaro tank fits in the back
https://vetteworksonline.com/catalog...bn5u3tuo45g5k6
Old 01-02-2021, 08:37 PM   #5
gmc684x4
Re: LT4 Upgrade
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
Old 01-05-2021, 09:00 PM   #6
cornerstone
cornerstone's Avatar
Re: LT4 Upgrade
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 01-06-2021, 10:36 AM   #7
SCOTI
SCOTI's Avatar
Re: LT4 Upgrade
Reno...
Any specific areas you're wanting to focus on?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2021, 02:42 PM   #8
siggyfreud
siggyfreud's Avatar
Re: LT4 Upgrade
Is the ZR1 a wet sump system?
Ensure you get the right PWM fuel pump for it otherwise you'll have nightmares getting running.
siggyfreud is offline   Reply With Quote
Old 01-09-2021, 02:36 AM   #9
zschary
Re: LT4 Upgrade
this is prob a wet sump, no dry sump in camaros that i know of.. here is a link to the tank i used putting a new silverado engine in my 67.. it has the mount for a ZL1 style fuel pump that works great with these engines with direct injection and the high pressure mechanical pump Siggyfreud is right go OEM on pump if you can
https://fueltankparts.com/collection...em-mu2101-pump
zschary is offline   Reply With Quote
Old 01-09-2021, 03:45 AM   #10
SCOTI
SCOTI's Avatar
Re: LT4 Upgrade
ZR1 (Vette) is; ZL1 (F-body) isn't from what I've read about them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-09-2021, 06:13 AM   #11
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: LT4 Upgrade
I've been looking at LT's as well but the donor cars are still bringing a premium around here. I'm in to follow and learn.
Ryan
1969 Chevy milk truck
Old 01-09-2021, 11:35 PM   #12
zschary
Re: LT4 Upgrade
dont forget about the L83 and L86 silverado engines... L86 is basically an LT1.. I put an l83 in my truck, i got it and the 6 speed auto with 30 thou for 2500 .. Same direct injection etc..
Old 01-10-2021, 12:33 AM   #13
siggyfreud
siggyfreud's Avatar
Re: LT4 Upgrade
Yeah I was just a little confused because he said ZR1 Camaro, so wasn't sure if he meant ZR1 Corvette, or ZL1 Camaro .
Yep, ensure you get the right feeder pump, either OEM or an Aeromotive that's compatible with a pulse width modulation signal. Some magazines got an LT1 and LT4 started without a PWM pump (just used a regular instead) but couldn't get it running right afterwards.
Old 05-25-2025, 12:39 AM   #14
Jessdigs
Junior Member
Re: LT4 Upgrade
Following along as I’m doing the same. 70 cst, I bought a 2018 LT4/10L90 out of a wrecked 2018 ZL1 Camaro. Working wiring harness from spear tech. I’m going aftermarket chassis.
Jessdigs is offline   Reply With Quote
Old 05-25-2025, 01:20 AM   #15
Jessdigs
Junior Member
Re: LT4 Upgrade
Old 05-31-2025, 01:33 AM   #16
Richard
Re: LT4 Upgrade
I had posted but deleted it. OP has not added anything since the first post in 2021.
Richard
