Dash lights
I'm having trouble with my dash lights going out,sand melting switch. Tail lights still work. New harness ,led dash lights ,has happened twice now.68 c10 panel. Mcbchev
![]() Join Date: Apr 2016
Re: Dash lights
More information, pictures, fuse box and fuses in it, etc.
![]() Join Date: Aug 2019
Re: Dash lights
I have seen that problem caused by the bulk head connector. Check the connection under the hood.
Re: Dash lights
Re: Dash lights
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Dash lights
Check the electrical forum in my FAQS thread for info on the dash lights. There may be something there to help you.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#7 | |
The Older Generation
Re: Dash lights
http://67-72chevytrucks.com/vboard/s...d.php?t=815300 LockDoc
Re: Dash lights
I would guess its dirty connections including grounds all through your lighting circuit. Also if you are running halogen bulbs this will add a lot of heat to your switch. I went with headlight relays and this helped a lot.
Re: Dash lights
LockDoc lots of great info on your link thanks.
Re: Dash lights
You can thank "VetteVet", he is the one that put it together. Posting the link here was the easy part.... ![]() LockDoc
#11 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
Msgt USAF Ret
Re: Dash lights
And thank you Doc for helping to get the word out.
