Old 02-23-2020, 08:52 PM   #1
71C10Guy
Alternative alternator bracket?
I have to stock 2 piece alternator bracket, and it's a total pain in the ass. The long top provides almost no support and the alternator ends up vibrating violently. I've been driving with it for a year now so it's not an emergency, but it pisses me off. Another thing, the bracket is not long enough to completely clear my valve covers, so the alternator rests on the side of the cover. When it vibrates it makes a loud metallic clanking noise that... is less than ideal.
I'm just wondering if anyone has had this problem and what they did to solve it? On another note, I added an aluminum bracket (piece of 1/8" sheet, bent and twisted) to the back of the alternator extending to the #1 cylinder exhaust bolt. It helps a tiny bit but not enough to make the alternator stop vibrating and rattling against my cover. Will include pics later.
71C10Guy is offline   Reply With Quote
Old 02-23-2020, 09:06 PM   #2
Mike C
Mike C's Avatar
Re: Alternative alternator bracket?
Interesting. I have 350,000 miles on my Jimmy OEM alternator setup and it is rock solid. It's the same setup used on C3 Corvettes from 69-82 and had no issue with the SHP motors that would pull nearly 7000 rpm with the 70 LT-1.
I would start trouble shooting to figure out what is wrong with your setup and correct that before re-inventing the wheel. Whether the bracket is broken, misaligned or something else going on.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-23-2020, 09:23 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have the stock alternator brackets on my 1972 with a stock alternator. It works just fine with no wonky vibrations. You need a bit longer fan belt if the alternator won't swing out far enough to clear the valve covers.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-23-2020, 09:32 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Alternative alternator bracket?
Is this a small water pump setup are long water pump? The tall valve covers will not let the factory brackets fit right. You will need to make adjustments for them.
Pictures would help.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-23-2020, 10:10 PM   #5
uncle
There are 2 different length upper brackets also which might help with valve cover problem.
uncle is offline   Reply With Quote
Old 02-23-2020, 10:31 PM   #6
Grumpy old man
Grumpy old man's Avatar
Here are the 2 different upper brackets .
Old 02-24-2020, 09:44 AM   #7
StingRay
StingRay's Avatar
I'll ditto the no problems With mine. On n my old 72 with stock brackets it always been rock solid and I run a modern 105 on it with significantly higher loading than stock. A couple hundred thou on the old girl. Perhaps send us a pic of your set up.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 02-24-2020, 11:39 AM   #8
Andy4639
Old member
Andy4639's Avatar
Question Re: Alternative alternator bracket?
Is this your type of setup?
Old 01-13-2021, 09:31 AM   #9
Bearhawg
Bearhawg's Avatar
My apologies for resurrecting and old thread but this is the best result from my searching. I am looking for the bracket shown in my picture that looks to match up with the ones in thread. Can anyone tell me where i can find one to purchase? I dont need the lower cast bracket that bolts to the head, just the upper adjuster bracket. I've searched the interweb and the closest match seems to be from a C2 Corvette, which makes it more expensive.
Thanks for your help.
Bearhawg is offline   Reply With Quote
Old 01-13-2021, 11:13 AM   #10
Andy4639
Old member
Andy4639's Avatar
Attachment 2073901
I have bought them at the parts store but they are chrome. I just paint over it. Easy enough.
https://www.google.com/search?q=c+10...w=1366&bih=625
https://www.cjponyparts.com/alternat...1966/p/ALTB49/
https://www.classicparts.com/1963-66...gaAmSuEALw_wcB
https://www.speedwaymotors.com/Chrom...UaAkWNEALw_wcB
Old 01-13-2021, 12:43 PM   #11
OL SKOOL
OL SKOOL's Avatar
Put this in the parts section as a wtb. I bought the same one off there worked good and reasonable.
OL SKOOL is offline   Reply With Quote
Old 01-13-2021, 04:36 PM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
Gotta be a subscribing member to post on the parts boards.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-14-2021, 08:29 AM   #13
Bearhawg
Bearhawg's Avatar
Thanks! Purchased from Classic Parts
alternator, bracket, general, rattling, vibrating
