Old 01-13-2021, 08:24 PM   #1
rechinca
rechinca's Avatar
Loose shaft in column
So part of my work was rebuilding the steering column. Took it for a maiden voyage and I can pull my steering wheel/shaft toward me about 1/2 -1”. What did I do wrong?
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-13-2021, 08:46 PM   #2
Boog
laying low
Boog's Avatar
Re: Loose shaft in column
Leave out the big spring and washer at the bottom of the column? It's the preload.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-13-2021, 09:16 PM   #3
rechinca
rechinca's Avatar
The spring and washer are there. I can pull up on it and the spring pulls it back down. How do I adjust out that preload? I think that may be my issue.
Old 01-13-2021, 09:38 PM   #4
C10DREAMER
Edited by Moderator:
What you posted was off-topic to this thread. Please start your own thread about your question instead of Hy-jacking this one.
Thanks,
LockDoc, Moderator
C10DREAMER is offline   Reply With Quote
Old 01-13-2021, 10:30 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Loosen the clamp bolt just above the intermediate shaft flex joint and put some upward pressure on the upper part of the intermediate shaft flex joint while someone holds down on the steering wheel to get the preload on the bearing retainer spring, then tighten the clamp while both are holding them. The preload distance depends on the year of your truck. The preload distance is measured between the large washer and the bottom of the bearing where the spring sits. On a '67 the distance is 7/8". I think the others are listed in the chassis service manuals.
LockDoc
Leon
Old 01-13-2021, 10:39 PM   #6
rechinca
rechinca's Avatar
LockDoc
Lock I just read a post you made a few years back explaining that (along with this one), went out and I’ll be. It worked perfect! Took about 2 mins and that included getting out the wrench and putting it away! Thanks for the info.
Old 01-13-2021, 11:12 PM   #7
LockDoc
LockDoc's Avatar
Good deal! I like easy fixes....
LockDoc
Leon
