01-14-2021, 01:45 PM | #1 |
Dropping steering column to access turn signal switch
So, I’ve already undone the 4 bolts on the bottom plate, that holds the steering wheel up and removed the parking brake cable but this only buys me an inch of working room.
Before I go and unbolt and detach everything under the sun, is there some particular items that need to be undone so I can get access to that one Phillips head bolt holding the turn signal switch in place? The placement of this switch so frustrating. 1960 GMC 1000 series, 3 on the tree. Thanks for any pointers. - Scott |
01-14-2021, 01:59 PM | #2 |
Re: Dropping steering column to access turn signal switch
Try loosening the clamp on the engine side of the firewall. That might give you enough room to drop it down some more
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-14-2021, 02:01 PM | #3 |
Thanks cwcarpenter98! I will try that now.
01-14-2021, 03:52 PM | #4 |
That did the trick! Thanks !
01-14-2021, 08:44 PM | #5 |
Sweet! I'm glad my guess worked for ya
