Old 01-15-2021, 06:38 PM   #201
Tempest67
Tempest67's Avatar
Re: 51 Chev on a S10 frame, named Dale
Hi Guys,
Took a bit of a break on the truck while it was being used outside with Santa.
I wasn't sure what I was going to do for door panels til I saw this youtube video and thought I would give it a try. https://www.youtube.com/watch?v=EHMEfFu2SsU&t=535s
So, I started with 1/8 fibreboard, spray adhesive, some 1/4 staples, some 3mm yoga mats, and some grey vinyl.
First I made a paper template of the door panel. I only made it to go down to the curve, as the fibreboard will not bend that much, and I plan to add carpet to the bottom 6+/- inches.
Then I cut out a piece of fiberboard and drew on my pattern. Ended up with 6 vertical panels at the bottom, and 1 large panel at the top that will have the window and door handle, as well as the arm rest. (originals from my 67 Tempest, painted and pads were wrapped in grey vinyl)
Then I cut each panel out of another piece of fibreboard, and glued pieces of the yoga mat to it. (cushion)
Then I glued and stapled each piece onto the full size door panel.
I have not installed them yet, as I will be doing a lot of interior work this winter and don't want them getting damaged.
For about $100 in material, here is what I have.
Tempest67 is offline   Reply With Quote
Old 01-15-2021, 06:43 PM   #202
Tempest67
Tempest67's Avatar
couple more pics
Old 01-15-2021, 07:23 PM   #203
28TudorAZ
28TudorAZ's Avatar
Originally Posted by Tempest67 View Post
couple more pics
Wow that looks great. Great idea.
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085
Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133
28TudorAZ is offline   Reply With Quote
Old 01-15-2021, 08:07 PM   #204
Father&son56project
That looks snappy. Its amazing what can come out of a simple, DIY approach. Keep the updates coming!
Father&son56project is offline   Reply With Quote
Old 01-16-2021, 09:27 AM   #205
8man
Very nice. What is the arm rest from?
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-16-2021, 10:50 AM   #206
youngrodder
youngrodder's Avatar
Very nice.....I thought upholstery work is fun. You can get creative with that is used under the material (cloth/leather/vinyl) for shape. I think most people would be surprised by the materials shops use under the various materials...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-16-2021, 01:28 PM   #207
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice! They look great.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-16-2021, 11:28 PM   #208
dsraven
great ingenuity. one problem though, you are gonna feel guilty when you're in there unless you do a couple stretches first, all because of those yoga mats. haha.
looks awesome.
Old 01-17-2021, 05:55 PM   #209
joedoh
joedoh's Avatar
nice nice work!
Old 01-17-2021, 08:54 PM   #210
olcarguy
nice
olcarguy is offline   Reply With Quote
Old 01-18-2021, 11:03 AM   #211
Tempest67
Tempest67's Avatar
Thanks for the comments.
It was a fun project, and a clean project, as I only had a little glue on my fingertips. -no grease, no metal dust from grinding, and no crawling around on the floor under the truck..... a nice change.
8man - the arm rests are from the front doors of a 67 Tempest. The rears are the same but have an ash tray molded into them. The painted part was originally chrome, on plastic, but these were old and had turned yellow, so I just painted them. They are the same on all Pontiac A Bodies, Tempest, Lemans, GTO, from 1964 to 1967, and maybe for Chevelle, Skylark, and Cutlass?? but not sure.(see pic)
Youngrodder - I have never really done any interior work before, but this was enjoyable. I originally was thinking of 4 vertical panels, then 5, and settled on 6. I decided to keep is simple, but the design possibilities are endless.
dsraven - when I purchased the vinyl ($40) I asked if they had any foam and they said No. So I had to find some foam and I thought of a yoga mat..... sounds crazy, but it works.
Still lots to do, rear roll pan, tail pipes, interior, radio... etc
Old 01-18-2021, 11:25 AM   #212
8man
Thanks Tempest, they look good.
8man-aka Robert
Old 02-22-2021, 01:13 PM   #213
Tempest67
Tempest67's Avatar
OK, it was time to finish up the rear. I wanted to add a roll pan and make 2 tail pipes.
First, I made a paper template of what I wanted, and a friend of mine bent the metal.
I then made 2 end pieces, welded them on, then, made a box and frenched in a place for the tag. I also notched the panel for the 2 tail pipes.
Once the roll pan was complete, I added a skim coat of filler to cover the bends from the metal brake and mixed up some paint (Tremclad/Rustoleum) and painted it.
Old 02-22-2021, 01:22 PM   #214
Tempest67
Tempest67's Avatar
Then, I had to try to be creative and add some patina.
When I drove the truck last Fall, it had no tail pipes, so after buying some 2 1/4 in pipe, 6 - 45* bends, and 2 - 90* bends, and I used some chrome tips I already had, it was time to create some tail pipes.
and here is the finished result.
I was thinking of using the bumper, but I like this, for now.
..... time to continue work on the interior.
Old 02-22-2021, 02:21 PM   #215
youngrodder
Great looking rolled pan...Nice touch to finish of the rear.
Marc
Old 02-22-2021, 04:48 PM   #216
6DoF
6DoF's Avatar
the back of the truck is real patina right? you NAILED the roll pan fotina if so!
6DoF is offline   Reply With Quote
Old 02-22-2021, 05:32 PM   #217
Tempest67
Tempest67's Avatar
The tail gate has been my test panel.
The original plan was to make the truck a light green, but then decided to match original. (and I added the reverse lettering)
see pics
Old 02-24-2021, 10:10 AM   #218
6DoF
6DoF's Avatar
well played, well played for sure.
Old 02-24-2021, 08:52 PM   #219
Jason 56
I like it. Great work!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 02-25-2021, 09:19 AM   #220
Father&son56project
That's really flying along now. Nice job on those interior panels and the roll pan! Did you ever sort out the non-functioning gauges?
Old 02-25-2021, 11:10 AM   #221
Tempest67
Tempest67's Avatar
Thanks for the comments guys.
Jason 56, you are one of the 'Metal Magicians' that inspired me to try and make the roll pan, thank you, I enjoyed the project.
Father&Son, the gauges were bothering me, and the mechanical speedo would not work with the NV3500 trans, so I broke down and purchased new Gauges. (install coming soon), also will be working on completing the interior. (headliner, rear cab panel, seat belts, radio, ...)
Old 03-04-2021, 02:47 AM   #222
joedoh
joedoh's Avatar
looks really good!
Old 03-08-2021, 01:25 PM   #223
Tempest67
Tempest67's Avatar
OK, time for an update on the Headliner.
I decided to keep the same style as the door panels, (5-6 inch wide grey panels) so purchased a sheet of 1/16 in fiberboard, some more grey vinyl, a couple more yoga mats, and some more contact cement.
I cut out the pattern (2 pieces) of the headliner and added an extra inch on both sides. The panels I made smaller, as the thickness of 2 panels, the foam, and the vinyl would not fit under the edge, so I would only need to put 1 layer of fiberboard under the edge with 1 layer of vinyl....make sense?
With the 2 panels placed beside each other, the seam is hidden.
Also, I added a bent metal panel (with yoga mat and vinyl) at each side as the fiberboard would not bend enough to curve over the doors.
Here are the pics, from design, to final pic with visors.
Old 03-08-2021, 01:50 PM   #224
8man
That's really nice.
8man-aka Robert
Old 03-08-2021, 02:06 PM   #225
NorCalGal
NorCalGal's Avatar
That turned out nice
Jan's 53
NorCalGal is offline   Reply With Quote
