Old 07-08-2004, 02:48 PM   #1
2low72
antenna delete????
Are there cowlings out there with no antenna hole ar do they have a plate to stick in it. i don't have a welder to fill the hole with, and need to do something because i have a french antenna where the fuel filler was..Thanks
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 07-08-2004, 03:02 PM   #2
Scrubby
Check out GMTrucks.org
If you can find the cowl off a truck that was radio delete, it will not have an antenna hole. I had one, but sold it for some good money at the portland swap meet last spring.
Scrubby is offline   Reply With Quote
Old 07-08-2004, 03:10 PM   #3
silvertonguedevil
silvertonguedevil's Avatar
They're pretty rare and usually bring some pretty good $$$ but they're out there.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 07-08-2004, 03:13 PM   #4
2low72
Then it might just be cheaper to have it welded? i guess i'll go that route i know what kind a price rare stuff can bring. and i not looking to spend a whole lot on this part. if i was restoring to original then i would. thanks for the input
Old 07-08-2004, 03:47 PM   #5
highboy_04
highboy_04's Avatar
i actually have one from a 69 but someone drilled a hole in it for an antenna
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 07-08-2004, 04:44 PM   #6
raggedjim
raggedjim's Avatar
I've got one, but it is going on my blazer. Before I found it I was planning on welding the hole, shouldn't be too hard.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 07-08-2004, 05:17 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I ALSO WAS LUCKY AND FOUND ONE, GOING ON MY BLAZER PROJECT UNLESS
THE ONE THAT COMES WITH IT IS THE SAME AS MINE, IF SO MINE WOULD B
4 SALE, CHECK BACK IN A WEEK OR 2 FOR THE VERDICT, I HOPE
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-11-2004, 10:39 AM   #8
2low72
Well found a guy at work with a welder, and I now have no more antenna hole. i also stripped it down to bare metal (Aircraft paint stripper....great stuff). and reprimed. thanks again for your inputs
