01-15-2021, 08:23 PM | #1 |
Would like intermittent wipers in my 78 GMC
I've read a number of threads about this, but it seems to come down to finding an intermittent wiper control module. Seems that the control modules are hard to come by. Does anyone know of a source for these, or an aftermarket solution?
Thanks!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-15-2021, 08:41 PM | #2 |
Re: Would like intermittent wipers in my 78 GMC
Were intermittent wipers even an option with the dash-mounted switch?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
01-15-2021, 09:33 PM | #3 |
Just here to tinker
I believe they had an option for intermittent wipers these years. Instead of the metal square knob for the wipers, there would be a little round black knob with an arrow on it. You turned it to adjust the intermittent. I don't think they worked very well....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
01-15-2021, 09:35 PM | #4 |
Just here to tinker
They looked like this.
01-15-2021, 09:53 PM | #5 |
Yes, they would look like the picture posted above.
Adding the intermittent portion is pretty easy, as you’ve read. It’s been added to my ‘78 Chevy, and is as simple as finding the module on a parts truck, and the module is plug and play. As far as I know, the module is not currently being reproduced by anybody, and supposedly they have internal component failures, but I’ve seen them be repaired before. Your best bet would be to find one at a wrecking yard or someone locally parting out one of these trucks, and bring your truck so you can test it easily. |
01-15-2021, 10:04 PM | #6 |
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
01-15-2021, 11:03 PM | #7 |
I had a 79 Camaro with a switch similar to what Corts60 posted. The intermittent function worked fine until something went wrong and the wipers wouldn't turn off reliably.
Guessing you could expand your parts search to all mid to late 70's GM vehicles and not just trucks. A lot of parts from that era were common across the various GM lines. |
01-16-2021, 09:20 AM | #8 | |||
