Old 01-16-2021, 02:06 PM   #1
elorenzof
71 K10 Fuel Tank relocate
Good Morning,
In building my 71 K10 shortbed fleetside, i would like to install the fuel tank in the rear frame area using Tank's Inc 69 Camaro Fuel tank. I have searched the threads and found many threads i see that pertain to C10's not K10's as they all have trailing arms and springs vs. the leaf spring set up. I want the fuel filler to come out of behind the license plate area. Is there anyone out there that did this mod to their K10 that can share mounting ideas and pics to help me out?
I am installing the original 350 turned into a 383 Stroker. (not pertinent but...)
Thank you in advance.
elorenzof is offline   Reply With Quote
Old 01-16-2021, 02:53 PM   #2
landarts
landarts
Re: 71 K10 Fuel Tank relocate
What you are trying to do will work. C10 or 4x4 will not make a difference in the frame in the rear where you want to put it. I used the Mustang tank and 90 ohms fuel sending unit from tanks Inc. and it worked perfect. I went with this tank because it is low profile and can not be seen hanging down, also fits between frame rails. Camaro tank is also a great choice.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-16-2021, 03:04 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 71 K10 Fuel Tank relocate
Originally Posted by elorenzof View Post
Good Morning,
Call Rob @ No Limit engineering in Tenn. He is also a member on here. I bought his tank. Yes it's for a trailing arm truck. But he knows these trucks inside and out. He can tell you if there is any problems with his tank and leafs which I wouldn't think so since the tank fits inside the frame and the leaf attaches to the outside. He can also make whatever you need and he can put the filler wherever you want it on the tank.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-16-2021, 03:31 PM   #4
gmc684x4
Suburban blazer tanks fit well between the frame rail
gmc684x4 is offline   Reply With Quote
Old 01-16-2021, 04:44 PM   #5
elorenzof
Thank you everyone for the quick replies! I will call Rob @ No Limit thank you for that suggestion. Aslo, on the Mustang Tank from Tanks Inc, What year of Mustang tank did you get, and do you have any install pics where you did the straps, etc. Is it a rear fill so i dont have to deal with any fancy fuel filler? I just want to keep complicated down to a minimum.
Old 01-16-2021, 04:54 PM   #6
Andy4639
Old member
Andy4639's Avatar
Robs tank sits on the frame rails lip no straps. He does send bars though.
This was in my 68 step. I sold the truck before I finished it so I never got to try it out. Rob will help you with anything you need. I had him go ahead and do the fuel injection sending unit mount even though it was a carburetor just in case. No extra charge. I ended up not using the 2 extra bar straps. The frame rail held it nicly.
