09-08-2013, 03:50 PM | #1 |
A pillar drip rail removal - DIY
This is actually pretty easy. Wedging the putty knife helps prevent cutting into the A pillar. Repop drip rails are available from vendors. Once I make the repair, I'll add to this post.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
09-08-2013, 04:17 PM | #2 |
Re: A pillar drip rail removal - DIY
Great write-up! Thank you.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
09-08-2013, 04:56 PM | #3 |
Nice! I never even thought about that area getting rusty. I'm outta here to go and check it!
66 shorty |
09-08-2013, 05:46 PM | #4 |
Who Me?
Nice job!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
09-08-2013, 05:49 PM | #5 |
Mine are on the list to be done, good post.
Posted via Mobile Device |
09-08-2013, 06:34 PM | #6 | |
Any chance the moderator would let me correct that photo?
09-09-2013, 02:29 AM | #7 |
Hollister, CA.
The text was added to your photo.
You will need to correct the text in the photo, and upload it to photobucket again. Then edit that post to change the url ....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
09-09-2013, 03:37 AM | #8 |
Hollister, CA.
I know that ...
But he has to change the text on his end first
09-09-2013, 05:21 AM | #9 |
I'm wonderin how the truck would look, doors closed, A pillar drip rails missing?
09-09-2013, 10:33 AM | #10 |
Senior Enthusiast
Thanks for taking the time to document and share this information.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
09-09-2013, 10:37 AM | #11 |
Great write up....
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-09-2013, 11:31 AM | #12 |
I just fixed the original photo 5 on photobucket with the same URL. We'll see if it changes.
09-09-2013, 11:16 PM | #13 |
It's good to know they repop this,as I know I need to replace mine.Thanks for sharing. BTW how much are the repop drip rails...
1964 BBC 402 4x4 |
09-10-2013, 09:35 AM | #14 | |
The method of installation and factory design of these drip rails makes them a water trap. Once the seam sealer cracks enough for water to get in, the rust will never stop. Some folks delete them, but that might create other issues with the door seal etc. I plan to put mine back on. I'll post picks when I do.
09-10-2013, 01:51 PM | #15 |
Do the drip rails matter much only for driving in the rain or will there be door seal issues even if its just parked in the rain without those drip rails?
I wonder how much wind noise they are responsible for.
1966 C10 250 with 3 on the tree Build Thread Bunch of other cars no one cares about |
01-13-2021, 11:06 PM | #16 |
Installation methods?
I was thinking to pop-rivot in place or possibly using body panel adhesive. Thinking the adhesive may be the way to go. The stuff is solid; If i glue in the entire face of the rail to the A pillar it would be 100% sealed up Something besides spot welding back Posted via Mobile Device |
01-14-2021, 10:17 AM | #17 |
Here’s a link to my original photos in case photobucket goes down. I no longer have an active photobucket account but my website is always best anyway.
A Pillar Drip Rail Removal - DIY
01-14-2021, 04:08 PM | #18 | |
01-14-2021, 08:26 PM | #19 |
I was originally going to leave mine off but it would take a lot of metal work to make the door and the a pillar lineup so it looks right so I glued them back on I don’t think it would have any thing to do with how the door seals
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
01-14-2021, 09:09 PM | #20 |
What did u use?
I was thinking 3m body panel adhesive |
01-15-2021, 09:18 AM | #21 |
Yep I also used three screws and then filled the holes with the same
01-17-2021, 10:49 AM | #22 | |
01-17-2021, 10:55 AM | #23 |
I’d move it up. There should be a small drip hole in the roof rail too.
01-17-2021, 01:14 PM | #24 |
There is
Wasnt sure how close it was suppose to be Posted via Mobile Device |
