Old 01-15-2021, 03:51 PM   #1476
LEEVON
Moderator
LEEVON's Avatar
Re: 53 Surburban "Family Truckster"
Marc omg that seat! Wow!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-15-2021, 04:13 PM   #1477
youngrodder
youngrodder's Avatar
Thanks man....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-17-2021, 10:03 PM   #1478
youngrodder
Today I worked on some odds and ends. My license plate mount was crooked (my fault) as seen in the pic and it bugged me. I cut it apart to reweld in an effort to straighten it out. (no pics of the correction).
I also tapped in to my running light feed to power the license plate lights.
Since my license plate mount is basically a hitch receiver inset I needed to be able to unhook the wires that power the license plate lights. For this I purchased a 2 wire water tight connector off of EBay. This way when I remove my plate to inset the hitch I can unplug the power supply.
For a clean solution I choose to use the license plate LED bolts. I used the same thing on my 48 and they also worked great. I will mount them at the bottom of the plate shooting up.
Marc
Old 01-17-2021, 10:18 PM   #1479
youngrodder
Dome Light LED upgrade.
I figured there might be some interest in this upgrade, so I broke it out on its own page.
I removed the OEM light socket from the housing.
I purchased a 24 light LED panel (Found on Ebay for $7.00). This will put out a lot of light. You can also get smaller panels like 18 light ect.
I added longer power and ground leads to the LED panel. I also added a 2nd dome light in the roof of my suburban for adequate lighting.
You can use whatever you like to secure the LED panel to the housing. I used 3m strip caulk that I balled up as I had some laying around. The panel is feather light so you could really use 3M double sided tape or hot glue.
With the frosted glass light lens, you don't see the LED panel or black strip caulk.
I also used some more strip caulk to create a gasket around the wired exiting the housing.
Any ??'s please ask but its fairly straight forward.
Marc
Old 01-17-2021, 10:24 PM   #1480
mongocanfly
mongocanfly's Avatar
I like the Interior light mods...that should work great
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-18-2021, 11:30 AM   #1481
lower50's
lower50's's Avatar
License plate and interior lights are great idea I'm going to have to steal this from you.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-18-2021, 11:36 AM   #1482
Tempest67
Tempest67's Avatar
Great idea...
Tempest67 is offline   Reply With Quote
Old 01-18-2021, 12:22 PM   #1483
youngrodder
Thanks Mongo..
That's why I'm not sharing ALL of my ideas with you thief's...ha ha. Steal away. They both are great cheap solutions. They both worked fine for 7+ years in my 48.
Originally Posted by Tempest67 View Post
Great idea...
Thank you
Marc
Old 02-06-2021, 01:17 PM   #1484
doowopper
lots of great ideas...roger
doowopper is offline   Reply With Quote
Old 02-07-2021, 01:52 AM   #1485
Dan in Pasadena
Dan in Pasadena's Avatar
I know SQUAT about LED's. I assume since you didn't mention it, they use full 12v power?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-08-2021, 09:12 AM   #1486
youngrodder
Thank you Roger..much appreciated.
Dan, yes they use the full 12v. No need for resistors or anything. I also a strip of LED lights under the dash shinning at your feet when the dome light comes on. These LED strip lights have an adhesive backing so they can be stuck anywhere, they are cheap and you can cut them to what ever length you like which changes how much light they put out.
Marc
Old 02-08-2021, 11:52 PM   #1487
Dan in Pasadena
Thanks Marc - for your explanations to some with "lame-old-dude-itis"!
If you've posted it maybe I've missed it but whose door switches are you using? I've heard all sorts recommended makes.
Old 02-09-2021, 09:08 AM   #1488
youngrodder
We ALL learn something from this site (young or old). I have not purchased my switched yet. I will probably go with ones similar to those that I used on my 48 which were just universal contacts.
Similar to these. Nothing fancy. You can also get some with plastic/rubber end caps.
https://www.summitracing.com/parts/prf-80170
Marc
Old 02-12-2021, 01:09 PM   #1489
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I really like the LED upgrade! I added 3rd brake lights to the cargo lamp on my 72 and now wish I would have done something like this for the cargo lamp. Did you add the frosted finish to the lens? I've been wondering id media blasting them is a sufficient way to accomplish that?
Ryan
1969 Chevy milk truck
Old 02-12-2021, 04:17 PM   #1490
youngrodder
Ryan
Thanks mam.....
No the lens is frosted from the factory. It's an OEM glass lens. They sell rattle can paint to add a frosted look. I bet you could spray the inside of the lens. That way it would still look glossy from the outside. LED's don't put out any heat so I bet it would hold up fine and might be a better option than blasting the lens. Just keep applying light coats to get the desired amount of frosting.
Just a thought (outside the box)
Marc
Old 02-13-2021, 10:53 PM   #1491
youngrodder
On Friday night I started fitting and working on my lower dash panel my friend Zach made for me. The first picture I taped on the AC vents to get an idea of placement. I then cut in holes for the vents as well as the AC controller as well as the wiper and light switches. This is the last part that needed to be modified before I get it painted to match the rest of the dash.
As a refresher this panel is the reason I cut my dashboard straight across on the bottom. I did something very similar on my 48. I like to utilize this lower panel to keep the main dash free of switches and knobs....
Marc
Old 02-14-2021, 10:20 AM   #1492
8man
Very nice look on the dash.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 02-14-2021, 10:24 AM   #1493
oldman3
oldman3's Avatar
Marc, looks good, like the placement...Jim
oldman3 is offline   Reply With Quote
Old 02-14-2021, 10:29 AM   #1494
youngrodder
Thanks guys....
Marc
Old 02-14-2021, 12:57 PM   #1495
layinrocker65
layinrocker65's Avatar
Looks great
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 02-16-2021, 03:41 PM   #1496
Tempest67
Tempest67's Avatar
Marc
D'Oh ! not sure why, but don't let this happen to your door switch
Old 02-16-2021, 04:42 PM   #1497
youngrodder
Originally Posted by layinrocker65 View Post
Looks great
Thank you
OUCH!! I had similar ones on my 48 and had no issues. I'm guessing it needed to be adjusted more so it didn't stick out as far from the door opening. Looks like it caught the edge and folded it over.
Marc
Old 02-16-2021, 04:56 PM   #1498
Tempest67
Tempest67's Avatar
ya, I think you are right, it sticks out too far.
The funny thing is it still works fine.
Old 02-16-2021, 06:41 PM   #1499
olcarguy
If it works it aint broke
olcarguy is offline   Reply With Quote
Old 02-17-2021, 03:12 AM   #1500
lower50's
lower50's's Avatar
Nice touch. It will hide the ac pipes as well.
1951 MG TD
