Old 01-12-2021, 01:45 PM   #101
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1972 Chevy Crew Cab “Denali”
I love this truck! Have I said that before?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-12-2021, 08:38 PM   #102
cornerstone
cornerstone's Avatar
Awesome work on the passenger seat tracks man. Whoever gets the privilege of sitting in that seat better put that thing to use a whole bunch.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 01-12-2021, 08:44 PM   #103
ShortbedClayton
Thank you. Yes the future Mrs. better enjoy them 👌🏻
ShortbedClayton is offline   Reply With Quote
Old 01-18-2021, 08:10 AM   #104
ShortbedClayton
Nothing exciting really to update the build with... got the rest of the crossmembers installed into the frame where I thought necessary. I mounted a 2wd automatic trans crossmember upside down after my double trans crossmember with skid plate. I flipped it upside down for driveshaft clearance. Next I tried to copy the crossmember between the rear spring hangers. Super happy with how that came out.. I bolted that in just about between the rear cab mounts. Trying to keep the underside looking factory. Coming out decent..
Old 01-18-2021, 12:12 PM   #105
72 tigger
72 tigger's Avatar
Very impressive fabrication!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 01-24-2021, 06:48 PM   #106
darguy
darguy's Avatar
You have some mad fab skills, and a great shop space. I'm jelly!
Cheers,
D.
'72 K-20 Frankentruck
'68 Beaumont Wagon
'05 Chevy G2500 Camper "Tiki Van"
'22 Honda CB500X Island-Hopper
darguy is offline   Reply With Quote
Old 01-24-2021, 07:46 PM   #107
ShortbedClayton
Moved up to the motor compartment to tackle some things up front. First step was switching from a long water pump to a short water pump so I can use all the factory 1972 brackets. Took me a bit to figure out all the AC compressor brackets but I got everything bolted up and looking right. Still have to change the power steering pulley as this one is bent. I got one on the way. Nest step is to get some headers to fit up and hopefully clear my 4 speed Z bar linkage.
Old 01-24-2021, 07:56 PM   #108
ShortbedClayton
Had some BB headers laying around but they hit the frame everywhere so I spent about 2 hours online looking for some and reading others build threads about what they used. I settled for some hookers (520-2463) from jegs. First step was getting the pivot ball and Z bar working. Had to make a bracket to bolt onto the block and then tap a hole 2” back and thread the pivot ball into... headers came in this week so I was excited after work to bolt them on. Passenger side fell on. No dents in the pipes or grinding on the frame. Drivers side cleared the frame well but of course they hit the Z bar. So I guess I’m modifying the rear primary tube to clear it. After a couple hours and a piece of tubing from pep boys I got them clearing the linkage. Touched them up with some high temp paint for now but I thinking about wrapping them when the time for final instal comes.. I did grind the frame about a 1/4” at one spot simply to make final install easier..
Old 01-24-2021, 08:02 PM   #109
ShortbedClayton
Bolted up the new rad support and got my OEM fenders bolted on for mock up. Had to shim the cab up front to get the gaps tighter. Dropped in a used 4 core and a BB shroud to check clearances. Have to do some trimming on the shroud so it drops down about a 1/4”. The fan clears but I’d like some more gap on the bottom side. My trim order from Mar-k came in this week as well. Was super excited to get that stuff. Quality seems top notch and was packaged very well!
Old 01-24-2021, 08:04 PM   #110
ShortbedClayton
Cheers,
D.
Thanks my friend! Appreciate the compliment. Yeah I’m definitely spoiled with the garage set up. Never really did sheet metal fab before this but I definitely dove in head first! I love it tho
Old 01-24-2021, 08:05 PM   #111
ShortbedClayton
I love it too. Thank you!
Old 01-28-2021, 06:36 PM   #112
ShortbedClayton
Dig out the old sidewinder winch I picked up last year and started to fab up some mounts. Rear frame mount and rear winch mount were still attached to the winch so I started there. I moved the winch as far back as possible to hopefully keep the bumper trimming at a minimum. Started with a 2.5” angle iron for the front. After some cutting and welding we have a front winch mount. Got a bumper out of the scrap pile to practice on the notch. After a few hours I got a notch I was happy with.. Now I can say 3 hooks are better than 2 😎
Old 01-29-2021, 11:19 AM   #113
3757chevy
3757chevy's Avatar
Very nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-08-2021, 11:54 AM   #114
ShortbedClayton
Started playing with some trim this past weekend! Been waiting a few years for mocking up some trim on a shortbed crew cab. Love the look so far!
Old 02-08-2021, 12:38 PM   #115
1971Stepside
Almost Satisfied
I like the trim, but look at those new shoes!!
Old 02-08-2021, 12:42 PM   #116
ShortbedClayton
Oh yeah I’ve had them for a few years now. Throw them on from time to time to look cool. I’ll use them for shows. I don’t quite know what I’ll run for daily driving
Old 02-08-2021, 03:31 PM   #117
Custom 68
Custom 68's Avatar
You are just scooting right along. It is coming together nicely.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-15-2021, 12:46 PM   #118
ShortbedClayton
Got both the upper and lower trim shortened up for the third and fourth doors over the weekend..
Old 02-15-2021, 05:34 PM   #119
3757chevy
3757chevy's Avatar
Looking real nice.
MIKE
Old 02-23-2021, 08:07 AM   #120
ShortbedClayton
Got all the trim holes drilled on the passenger side. Dry fit upper and lower trim and rolled the truck outside to stand back and see how straight the trim was... it was nice to take advantage of that white background as well. One pic is the factory 3rd door with my shortened trim installed. Pleased with its outcome. Onto the drivers side.
Old 02-23-2021, 08:18 AM   #121
72gmguy
72gmguy's Avatar
Looks awesome. I really like this!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 02-23-2021, 10:07 AM   #122
1971Stepside
Almost Satisfied
You are clearly in over your head here. I think you need to stop while you are ahead and just sell me this project so I can then be in waaaay over my head! LOL This build is so cool and going to be amazing. Love the trim work. Keep it up and please post a pic every day or so
Old 02-23-2021, 10:19 AM   #123
ShortbedClayton
Thank you! I try to post something once a week! Build progress is been slow with the snow and cold.
Old 02-23-2021, 09:18 PM   #124
Bones72Super
Bones72Super's Avatar
Looks amazing Clayton! What a difference a little buffing makes on that old paint
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 02-23-2021, 09:31 PM   #125
regan wilson
regan wilson's Avatar
That thing is awesome. I love diesel power but I'm glad to see a BBC in it.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
