Old 01-16-2018, 03:30 PM   #26
hewittca
hewittca's Avatar
Re: 1983 Chevy John Deere Re-power
Very cool project. I love seeing stuff like this.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-16-2018, 04:28 PM   #27
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! Have you called inline tube for your brake lines?
https://www.inlinetube.com/
Ryan
1969 Chevy milk truck
Old 01-16-2018, 06:01 PM   #28
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Super cool! nice work
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-16-2018, 11:06 PM   #29
sweetk30
sweetk30's Avatar
funny my buddys truck with early ext slave 4500 works just fine with stock hydro master .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-17-2018, 12:21 AM   #30
BlueBullet
BlueBullet's Avatar
Cool build I'm in!!
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 01-17-2018, 12:22 AM   #31
Dieselwrencher
We used a stock chevy master on my brother's V30 when we put a NV4500 in it. The master gave out after 3 months. We then went to a dodge master because we had a heavier than stock pressure plate load in it.
Ryan
Old 01-22-2018, 08:09 PM   #32
jhama78
jhama78's Avatar
Awesome project!! Looking forward to seeing more updates
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 03-05-2018, 09:59 AM   #33
Randallsauto93
Big thanks to Ryan for recommending Inline Tube for my brake line kit on this project. I ordered an entire stainless pre-bent line set, with the stainless steel extended hoses, & the entire clip mounting set. They shipped the same day I ordered them! The brake line installation went very smooth & easy. I had to remount the proportioning valve to my fabricated front cross member, that took some time & adjusting. But we now have brakes! On to the next step... Thanks for looking & all of your kind comments!
Randallsauto93 is offline   Reply With Quote
Old 03-05-2018, 02:19 PM   #34
Deer_hunter_088
Deer_hunter_088's Avatar
Im in.
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 03-05-2018, 08:37 PM   #35
Dieselwrencher
That's awesome! Those look very nice!
Ryan
Old 03-05-2018, 09:32 PM   #36
Dads79GMC
Dads79GMC's Avatar
Love it!!! Looks great!!! Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 11-06-2018, 02:27 PM   #37
Randallsauto93
Slow progress. After mounting the front fenders & hood, I discovered the water pump I had originally picked out for the motor will not work. The thermostat housing would not allow the hood to shut down. I was able to purchase a smaller reman John Deere water pump that bolted right up to this block. I also purchased a used thermostat housing off of a 4 cylinder Deere motor that was shorter, allowing hood to shut with no issues. I need to hang an alternator & power steering pump next. Thanks for looking!
Old 11-08-2018, 07:34 PM   #38
Dieselwrencher
It's all that stuff that can really put a snag in your progress. Nice solutions. It is looking nice!
Ryan
Old 11-10-2018, 09:47 AM   #39
Very neat and interesting project. Looking forward to seeing more on it.
Old 11-12-2018, 02:26 PM   #40
kipps
This is the engine for a 2950 or 2955, right? It looks very similar to our 2750, just with the two extra cylinders.
Were you able to merely flip the exhaust manifold over, or did you do a bit of re-drilling?
How much does this thing weigh compared to a cummins?
What pump do you have on it? It looks like a stanadyne. I thought those would have come with a roto-diesel.
That engine was something like 95 hp in a tractor. Can you get 200-ish hp out of the thing?
kipps is offline   Reply With Quote
Old 12-03-2019, 11:12 AM   #41
JDFarmBoy
Cool project!! Did this ever get finished? Any updates?
JDFarmBoy is offline   Reply With Quote
Old 12-04-2019, 01:27 PM   #42
daddyjeep
daddyjeep's Avatar
I would love to see an update.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 12-04-2019, 05:12 PM   #43
kipps
Me too! I want updates!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
Old 12-04-2019, 10:07 PM   #44
superdav
superdav is offline   Reply With Quote
Old 03-13-2020, 04:31 PM   #45
Randallsauto93
I started this project when I was 16 in my Dad's shop. 11 years later, now that I live 2 hours away it has been a real pain trying to get any progress on this project. I recently purchased a property with a nice sized shop, So I loaded it up & took it home with me! Now I can really start making progress. Thanks for following along.
Old 03-14-2020, 10:28 AM   #46
LT7A
Great! Glad you have a shop and get to continue.
Old 01-18-2021, 01:52 PM   #47
Randallsauto93
I decided to mount the power steering pump on the driver's side of the engine, with hopes of utilizing all the OEM hoses for the hydroboost & steering gear. In the end, I only had to have one hose custom made 4.5 inches longer for it all to work. The automotive V-belt pulley was for a 3/8 belt, & I could not locate a pulley that would work with this pump that was 1/2 wide to match the Deere harmonic balancer. So I had a machine shop turn out a hub for me that I welded to a 1/2 V-belt pulley
Old 01-18-2021, 02:09 PM   #48
Randallsauto93
Next up - 4 inch air intake for the clean air entering the turbo charger. It was a tight fit, but I was able to sneak the intake under the steering shaft & bring it over to the driver's side fender. Eventually when I add the 2nd battery box, this may be in the way & I will have to change it up a bit, but it will work for now. Thanks for following along!
Old 01-19-2021, 11:39 AM   #49
daddyjeep
daddyjeep's Avatar
Glad to see you are still at it.
04 1500 crew cab
Old 01-19-2021, 12:00 PM   #50
WilliamFd55
2nd that!
WilliamFd55 is offline   Reply With Quote
