#26 | |
![]() Join Date: Jul 2000
Re: Trying to do the logical thing.
Speaking of leaks, a cast aluminum pan will fix pan gasket leaks forever. I have also found that worn rubber motor mounts and trans mounts will let engine and trans move around too much, wearing out the shift shaft seal.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#27 |
![]() ![]() Join Date: Jan 2011
LS.
#28 |
#29 |
#30 |
I was kinda kidding, but just saying. For a fuel efficient driver you cant touch it with a carbed small block. The 700r will help, yes but I'm not sure I'd spend the cash to swap it. Tire size and of course shoe size matters too.
I like them all. I'm a BBC guy actually you just cant beat the LS for fuel economy. I'd save my 700r swap money and find a good 6.0 / 4L80. With respect to the purists if that's your taste, go with it. Just my opinion.
#31 | |
Make sure you have a large cooler on that transmission or you will cook it to death in o/d. |
#32 | |
Yes, you still have to install the TV cable correctly, but it's not rocket science. Pretty easy to do, especially with the pan off to make sure the TV lever is just touching the valve with throttle linkage at idle and choke open (no fast idle). In fact, I like a few thousands preload.
#33 | |
Track vehicle or week end short cruiser. ya, not much of an issue, something you drive a lot, it is a big issue. It gets costly when you burn up o/d gear. I ran a 2800 (non lock up) stall in a 2004r in a 3.73 geared 26" tall tire vehicle, and when in o/d the fluid temp gets toasty . The transmission would shift into o/d at 45mph, and that speed is much lower than the 2800 stall. I can only go by what I have seen with the 9 vehicles I have owned with the 2004r. I would not run one without a lock up converter and use o/d for any length of time. A simple switch, and you can have no lock up all you want,, then turn it on when in o/d or just cruising around and don't need the higher stall,unlocked converter .and have the transmission live a long happy life. |
#34 | |
#35 |
If you do go with a 700R4 check out TV-Made-Ez for Bowtie Overdrives. Their website sucks and half of it isn't working, but if you call them they're super helpful. I'm doing this swap currently just to make the highway manners better until I do my LT swap.
#36 |
Somebody watches Vice Grip Garage. That dude is awesome. A C10 is sitting for 23 years and he drives it home with just the tools you can find at AutoZone.
