Old 01-23-2021, 06:42 PM   #1
LS short box
Re: 72 C10 Chevy - LS with Entropy Radiator Lower Hose Solution
Great write up. Are those silicone hoses? If not I've great luck either making a one piece hose from a larger hose walking around the parts store stock room. Oreilly's typically has a good stock in the back room.
Or at NAPA they still have a hard copy parts book for hoses the give you basic dimensions for hoses. If you don't mod the hose you can send it back and get a new one.
Old 01-24-2021, 09:56 AM   #2
nsb29
nsb29's Avatar
Summit racing has a shrink clamp it’s a band that you shrink with a heat gun. I had to cut mine and use a tube so I turned my clamps so the adjustment was to the back side and painted them black, but I’m going to order the shrink bands for the splice. the only complaint I saw was a guy used to large of band and it didn’t get tight enough
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-24-2021, 02:28 PM   #3
roushinator
roushinator's Avatar
Yeah i am going to try those.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 01-24-2021, 09:08 PM   #4
nsb29
nsb29's Avatar
Call summit and make sure how it’s sized if it goes hose size or outside diameter it’s not clear at least not to me
