10-29-2020, 12:06 AM | #101 |
Re: 55 in NH build
The project is evolving again lol . I was able to pick up a 2016 LT1 and 8L90 transmission with 26k. 455hp 460tq should move it along. I'll be collecting parts for a while. I'm going to do the DOD delete and have an LT5 cam on order. I'm hoping I can make enough room to keep the factory accessories. This Gen V stuff is a pretty big learning curve for me but I'm pretty excited about the prospect.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
10-29-2020, 02:36 AM | #102 |
Re: 55 in NH build
Nice work on the build. That power train will make things interesting. Subscribed
10-29-2020, 09:32 PM | #103 | |
Re: 55 in NH build
10-30-2020, 12:59 AM | #104 |
Re: 55 in NH build
Looks familiar If you run into any questions, feel free to ask. How complete is the engine?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
10-30-2020, 09:26 AM | #105 |
Re: 55 in NH build
Thanks Jason. the engine was complete but the harness... looks like the salvage company just lopped off the BCM section and I had to purchase a new TCM that is being programmed. I figured I'll have to create a new trans tunnel as you but not sure if I will need to touch the firewall as much. im trying to keep the camaro accessories with the AC and Alt down low so I'll be moving the engine forward a bit to make some room.
10-30-2020, 09:53 AM | #106 |
Re: 55 in NH build
Having the BCM section cut off isn’t that big of a deal. You’ll just have to continuity track all the hots for the stand alone fuse/relay panel. Are you doing your own harness or sending it out? Are you planning on running The PWM fuel and cooling fan? Mitch at swap time is a great resource for these gen V engines.
10-30-2020, 10:10 AM | #107 |
Re: 55 in NH build
Ya I plan on having Mitch build the harness along with adding his hot rod module. Going to run the PWM fan and pump as well.
10-30-2020, 10:11 AM | #108 | |
Re: 55 in NH build
11-01-2020, 08:25 PM | #109 |
Re: 55 in NH build
Got the drive train pulled today. the SBC looks tiny next to the LT1. Hope to start mock up soon.
11-14-2020, 09:45 AM | #110 |
Re: 55 in NH build
Nice tractor.
12-11-2020, 07:38 PM | #111 |
Re: 55 in NH build
Been ordering parts while I wait for the engine upgrades to be finished. Got a shifter in. HDX gauges have been ordered. Vaporworx ZL1 pump ring and and fittings are in.
01-11-2021, 08:25 PM | #112 |
Re: 55 in NH build
Got the engine back from the builder today. A bit of sticker shock later... Ordering the wire harness this week. They said it will take 6-8 weeks.
01-13-2021, 12:13 AM | #113 |
Re: 55 in NH build
You’re making great progress. What fuel pump are you planning on using?
01-13-2021, 10:20 AM | #114 |
Re: 55 in NH build
I have a ZL1 pump with a Vaporwokx lock ring welded into the tank. Im curious as to the sound level. The PO had an external holley pump that was crazy loud
01-13-2021, 02:50 PM | #115 |
Re: 55 in NH build
chances are with a internal pump in the tank you wont hardly hear it at all. I have been using Walbro internal pumps in my streetrods for years (original equipement in Mustangs and Camaros) i love em and they last forever since the fuel cools them in the tank.
01-13-2021, 02:58 PM | #116 |
Re: 55 in NH build
That’s cool. I just ordered the same pump and ring to mount in my tank.
01-13-2021, 04:05 PM | #117 |
Re: 55 in NH build
I still need to order a fuel pump controller and low pressure sensor but will add that into my harness order
01-17-2021, 09:37 AM | #118 |
Re: 55 in NH build
01-21-2021, 12:01 PM | #119 |
Re: 55 in NH build
Last_Paladin and his boys helped me mock up the engine. So far its tight but looks like everything will fit. Getting closer
01-24-2021, 12:53 PM | #120 |
Re: 55 in NH build
started bolting on as many bits as I can before finalizing my engine mounts. So far it doesn't look like I'll need to cut the firewall at all. Also ordered a high hump transmission cover to clear the center of the 8L90E. It was only $45 so I figured it would be a good starting point if I need to modify further.
01-28-2021, 07:53 PM | #121 |
Re: 55 in NH build
Engine mock up looks good! I ran into the same problem with my 4l60e. The high hump gave me plenty of clearance.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-29-2021, 01:10 PM | #122 |
Re: 55 in NH build
looking good. What radiator are you using? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
01-29-2021, 03:48 PM | #123 |
Re: 55 in NH build
The radiator came with the truck. Seems like decent quality but can't find any name on it. Haven't decided if I will keep it long term. May have the top port relocated but I got a ways to go before I need to decide.
01-29-2021, 06:48 PM | #124 |
Re: 55 in NH build
Thank You. Steve
03-15-2021, 11:26 PM | #125 |
Re: 55 in NH build
My friend was able to relocate the inlet and outlet on my radiator and match up the size to the LT1 engine. Camaro fan installed and still has good clearance.
