Whats the Biggest Tire I can fit under my 98 blazer = NO LIFT ?
I'm looking to replace the tires on my 1998 Blazer 4x4
I believe they are current 225/75/R15's whats the Biggest I can go without lifting? i am looking at a set of BFG All-Terrians because i do wonder off into the bush while fishing and just want something a tad more agressive and a bit taller then my stock tires? also what would it take to get a set of 30-31's under my Blazer? would 2" blocks in the rear and cranking the bars up front work for 31's ? thanks Dave |
poker face
I had 265/75-15 BFG Longtrail tires on my '99 Blazer 2Dr with no lift. They are almost a 31-10.50. I would have had room (barely) to fit 31's. The wheels I had were the fat 5 spoke ZR2 style.
Cranking up the bars and blocks would not be needed for 30-9.50's. Those tires will fit a stock Blazer. A 30-9.50 is basically a 235/75 tire, which is not much bigger than what you've got.
If you could kick the person in the *ss responsible for most of your trouble, you wouldn't sit for a month. |
