Coolant leak from oil pan
Got the truck up and running and have been trying to figure out my coolant issue. Thought I’d post here to see. I have a LM7 in my 49 3100. Swapped the oil pan with one that has a lower profile, but seems like I have a coolant leak in one of the spots that had a hole for a bolt but my block doesn’t have a bolt hole. Anyone run into this? When it’s @ 190 seems to just pour from there.
Re: Coolant leak from oil pan
Think i found the issues. Coolant temp sensor is leaking I’ll swap it when engine is cool again. Odd that oil pan bolt is not there though.
60-66 Nut
I would have drilled and tapped the block for that bolt.
Looks like the gasket is off center on that hole
Be careful when you replace the temp sensor and don't over tighten as they will break quite easily. Ask me how I know.
Roto Reuter thats the name...
![]() Join Date: Feb 2010
My LM7 is the same as yours. No bolt drilled / tapped there.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Glad to hear that's all it was. Got to love an easy fix.
