BMW & ASE Master Certified
L83 DOD manifold oil supply plug
After experiencing what sounds like a collapsed DOD lifter, pulled the head and inspected #6 lifters they are locked in the right position compared to #4... not 100% sure as the heads still not back on it but after looking for solutions to prevent oil to enter the VLOM or LOMA found only one guy that sells a sleeve that looks like he tool a cylinder head down and ground it against the concrete..
Measured the hole, searched and found a dowel pin that is the right size. Spare VLOM with the solenoids removed.. ![]() Sleeve / dowel pin ![]() Installed with green locktite as a lube ![]() Reinstalled the hex cap plug, turned the manifold upside down and leak tested it.. it has a tiny bit of seeping air pressure, 125psi... prob not enough that it could reach the lifter to collapse it if a solenoid stuck open (since there a bleed off port/ screen). In the end, a complete DOD delete is the best, but this 3$ mod feels like it's worth it!
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: L83 DOD manifold oil supply plug
Interesting.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Put about 100 miles on since the replacement lifters and plug installation and good to go. So i would say i had either failing afm lifters on #6 or a leaking manifold... the engine has kess than 12k on it... but last 2-3k have been seen WOT atleast once per drive cycle
![]() Clint
What year is your engine? How many miles? Can I get to this without removing the intake?
#5 | |
clint
Mine is a 2014 and under hard acceleration it will back fire a little. 79000 miles and I am a little worried.
Do you have information on the plug you used?
BMW part number 11121726243 13.5mm dowel pin
It does need to be tweaked, I used a 1/4 deep socket that's slightly larger than the ID of the dowel pin to expand it a tad, forgot what size craftsman deep socket i used, but it was just just a little bigger than the ID and put tension when installing it. You need to measure how deep to drive the dowel pin in... i think its around .9 or so from the top surface to cover the oil supply hole. Simple harbor freight dial calipers is what I used and use for all my projects. if you drive it in too far, the oil supply hole will not be covered up and not sure if you can just drive another dowel pin in and hope for the best.. but measure and you'll be ok I think the oil supply hole is only .25" and the insert is like .5" so
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 01-26-2021 at 07:53 PM. Reason: updated for part number |
