01-25-2021, 12:27 PM | #1 |
Gas door
Has anyone seen this setup before, a gentleman sent me these pictures several years ago when we were discussing relocating the fuel filler. I found these a week ago and thought to not reinvent the wheel, he said it went well, however my geometry is not for s..t, making each piece and testing through that hole is not going well, I must be missing something. I am hanging up on the lower part of the light trim , just as it pivots out of the hole...?..
01-25-2021, 06:10 PM | #2 |
Re: Gas door
I think that there is a narrow curved metal part that the wiring loom is attached to. The hinge point would then be a few inches down inside the fender. I downloaded the photos, cropped and enhanced them, and that is what it looks like to me.
01-25-2021, 06:30 PM | #3 |
Re: Gas door
01-25-2021, 08:14 PM | #4 |
Re: Gas door
I was thinking along those lines, thought possibly the person that designed it would bring us up to speed, its not very accessible from below in the area the hinge would mount in, the two Phillips head screws must hold one portion of the mount.
I’ve got another design that I am trying, I’ll see how it works out.... |
01-25-2021, 08:52 PM | #5 |
But Found Her 25yrs Later!
Re: Gas door
Somewhere in these forums I saw someone else do the rear taillight access also - I don't remember who though.
01-26-2021, 04:46 AM | #6 | |
Moderator
Re: Gas door
Okay here is a thread - http://67-72chevytrucks.com/vboard/s...d.php?t=728072
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-26-2021 at 04:53 AM. |
01-26-2021, 12:07 PM | #7 |
Re: Gas door
I did a side marker fill setup on my 69 stepside, I;m wondering if you could put a shim between you light and hinge . Is it hitting bad or just a rub ? maybe all you need is just a shim in the right place to get it to clear
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-26-2021, 12:30 PM | #8 |
Re: Gas door
Fair contact, trying to keep the aluminum trim piece tight like stock to the body, just have to change my geometry on the hinge a bit, all trial and error, with me mostly error at this point, trying not to have to touch up paint anything, just working through the existing hole...2” wide...
01-26-2021, 09:10 PM | #9 |
Re: Gas door
After more attempts than I could count and countless parts manufactured that became scrap, it finally works...now on to the fuel filler...still have a bit of cleanup work on the hinge mechanism
01-26-2021, 11:42 PM | #10 |
Re: Gas door
Heyyy!!! THAT is SWEET! I am wondering if you can tell us what holds the tail light in place when it is closed? Magnetic? Spring loaded? Details please!
01-27-2021, 07:12 AM | #11 |
Re: Gas door
Most likely magnetic, just got to that point at my quitting time yesterday, still have more fine tuning to do...thanks for the kind words, after that battle they were well received......
01-27-2021, 03:22 PM | #12 |
Re: Gas door
Keep us posted on your progress. Thank you for sharing. Cheers!
01-28-2021, 03:26 PM | #13 |
Re: Gas door
After some modifications on the fuel filler, it now has a bracket and is mounted, no modifications to the inside of the bed, now on to the magnetic retaining mechanism.....
