Old 01-31-2021, 02:51 PM   #21
_Ogre
_Ogre's Avatar
Re: Steering column choice for 57
change out your column mount to have the column almost touching the dash
i'm 6'4" and raised the drivers seat 2" over the bench height to give me more leg room
i have the plastic column trim 1/4" away from the dash,
didn't realize i messed up until the speedo went in
i had to grind the point off my cluster trim ring
it works, it also looks like my wheel is higher than yours
i typically run the column tilt straight
shop air compressor timer
