Old 02-01-2021, 01:04 AM   #1
Swedchevy67
Brake booster
Need some answers about PB booster I bought.
The brake booster is for disc/drum and the
reason for that is that I was planning to
replace the front to disc. Now the corona
virus put me in a situation that the money flow
ended.
So my question is: Can I use the brake booster
and still have my drum/drum intact?
Swedchevy67 is offline   Reply With Quote
Old 02-01-2021, 01:36 AM   #2
gmc684x4
Re: Brake booster
Yes the booster can be used on drum drum setup
It is the proportioning valve that will need to be for drum drum did you save the old one?
Your master cylinder will need to be the booster style as well the difference is the depth of the pocket non booster master cylinder have a deeper pocket
gmc684x4 is offline   Reply With Quote
Old 02-01-2021, 01:56 AM   #3
Swedchevy67
Re: Brake booster
Old 02-01-2021, 01:57 AM   #4
Swedchevy67
Re: Brake booster
Originally Posted by Swedchevy67 View Post
.......and yes, I saved the old ones
Old 02-01-2021, 02:25 AM   #5
Swedchevy67
Re: Brake booster
Correct me if I’m wrong. So I need to have a booster with
less depth than the original????
Old 02-01-2021, 03:13 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake booster
Master and booster have to match up. Boosters normally aren't disc or drums. Has nothing to do with the kind of brakes you have. The master has to match the booster you use though.
If your drum brakes you have now had a booster you don't need to change anything. If your truck never had a booster then you just need a master for drum to drum that you should already have. My ramp truck with manual drums front & back. I just added the booster.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
