Old 02-03-2021, 06:22 PM   #10
Justin71105
Re: 1964 C10 fleet side swb
Originally Posted by SCOTI View Post
I would set-up the under dash brake pieces to be a 2-part 'modular' installation: parts contained under the dash connected to parts retained outside the firewall.
This allows for easy replacement of the brake booster for future service vs having to revisit fab work to make the set-up work. Is this how you ended up?
Yea to make a new booster work all I would need to do is cut off the ring, place the nub into the coupler end and then just adjust the coupler on the pedal side to make a tighter fit on the booster rod and tighten down my lock nuts.
Hard to make it work using the ring on the booster, it became a pivot point and would not let me push rod in straight.
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
BTR Truck Norris
Justin71105 is offline   Reply With Quote
