Old 02-06-2021, 11:00 AM   #1
xs-cash
LMC rear sway bar
Has anybody here bought and installed the rear sway bar from LMC? I’m thinking about it on my stock 72 1/2ton ,with rear leafs , stock height, is it worth it ?
xs-cash is offline   Reply With Quote
Old 02-06-2021, 09:46 PM   #2
young grasshoppa
young grasshoppa's Avatar
Re: LMC rear sway bar
I just installed the one sell at Truck and Car Shop (brand is ADDCO) on my '72 5/7 drop on leafs w/ a CPP front sway bar. I noticed an immediate improvement, I wish I would have done it when I put the front on.
young grasshoppa is offline   Reply With Quote
Old 02-07-2021, 01:07 AM   #3
Accelo
Accelo's Avatar
How about some pictures of the install? They don't come with any instructions, ones that are usable anyway.
Accelo is offline   Reply With Quote
Old 02-07-2021, 01:58 AM   #4
young grasshoppa
I did not take photos throughout, just have this one final one for now. Install was pretty straight forward, requires 4 holes to be drilled.
Old 02-07-2021, 09:33 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: LMC rear sway bar
Just info for you.
If you have the front bar on the truck, look into the 'No Limit" rear shock location kit. I took my rear bar off because it wasn't needed after installing Rob's kit. The kit moves the shocks out to the ends of the trailing arms. Makes a much better feel when taking curves.
If your truck is a leaf truck then never mind!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-07-2021, 11:52 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is there enough room to remove the diff cover without dropping the stabilizer bar?
~Steven
Simi Valley, CA
Old 02-07-2021, 12:04 PM   #7
Bigdav160
Bigdav160's Avatar
I don't have any pics but I installed the same addco bar in my Suburban but in front and on top of the pinion. The bar ends in my install face forward. I had to do this because my exhaust runs down the rear frame rails (rear mounted gas tank). I had to purchase longer links (4x4) but otherwise seems to work fine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-08-2021, 12:13 AM   #8
young grasshoppa
There's a few inches gap, getting the cover would not be a problem. It's pretty easy to move out of the way too.
Old 02-08-2021, 12:43 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thanks, that's good to know. I want one on mine because with the new shell and the Firestone tires, it has a little oversteer, without the trailer. If my wife was driving it, she'd panic, so I need to make it neutral. I'm already running 10 psi higher in the rear tires, per tire store recommendation.
~Steven
Simi Valley, CA
