Old 02-08-2021, 12:22 PM   #1
Pampas56
Dash lights
Now that the truck is running, I have discovered that the dash lights are not working. It seems that they have become the ground path for everything in the instrument cluster.
My BIL told me that it is a common problem with these trucks and I remember reading about this in past posts. I tried to search for the posts, but can't seem to find them.
I know I need to re-establish a ground path. BIL says to intercept the existing ground and carry it to a known good ground.
How do I do this? Do I cut into the wiring harness or is there a point in the cluster itself that I bond to, creating a solid ground?
I know that it is limited to the instrument cluster. The HVAC control lights up and dims as it should.
Any help or paths to the pertinent posts will be greatly appreciated
Steve
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 02-09-2021, 02:37 PM   #2
Mr_Rich
Mr_Rich's Avatar
Re: Dash lights
If this problem is on your '89 then it could be an open on the circuit board on back of the gauge cluster. It could be a matter of just detecting and re-soldering one of the circuits on the board. Newer trucks have this plastic circuit collection that clips on the back of the cluster; much different than the earlier trucks. I kind of learned this the hard way because I thought I could use a newer cluster in my '89 and they aren't compatible. Totally different plug design.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
