Old 02-11-2021, 04:16 PM   #1
a Good Man
a Good Man's Avatar
Dana gmc 1972 k2500
Hi
I have a question My k2500 72 very heavy and I need more speed Do I change Dana !?
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 02-11-2021, 05:52 PM   #2
a Good Man
a Good Man's Avatar
Re: Dana gmc 1972 k2500
What is the most appropriate measurement to increase the speed and reduce the pressure of the engine ?
MY Facebook
Old 02-11-2021, 08:42 PM   #3
52napco
Easiest thing is to swap an NV4500 5 speed or you could re-gear to 3.54 but you will have to buy 3 series carriers on both ends.
Spend extra money on good ring and pinions...hard to get a good pattern on cheaper gear sets.
52napco is offline   Reply With Quote
Old 02-12-2021, 06:17 AM   #4
a Good Man
a Good Man's Avatar
I appreciate this big brother and I will definitely replace gears, but I didn't understand what it meant ( buy 3 series carriers on both ends ) .. !
MY Facebook
Old 02-12-2021, 08:41 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What are the front/rear axles? Dana 44/Dana 60?
For some reason I’m recalling that 12 bolt rear axles need a series three carrier but those are for 1/2t applications not your k2500.
Can’t the D44/D60’s take 3.54 gear sets without need for carrier change?
Switching to 3.54 will help your cause. Alternatively, could add a Gear Vendors overdrive unit and keep the existing gears.
Old 02-13-2021, 02:49 PM   #6
a Good Man
a Good Man's Avatar
Thank you sir, are there any original parts numbers for me to purchase? Or is there an alternative company that is of high quality?
MY Facebook
Old 02-13-2021, 03:52 PM   #7
72Cheyenne454
72Cheyenne454's Avatar
As mentioned, a Gear Vendors Overdrive unit might be a better option for you, versus re-gearing both axles. Take a look at the links I've provided below. Currently, I have Gear Vendors overdrive units installed in two of my K series trucks. Both trucks have the NP205 transfer case, such as your truck, and the install is easy... compared to re-gearing both axles.
Here's an old article on installing a Gear Vendors unit...
https://www.gearvendors.com/4wheel-sep99.html
Here's the website for Gear Vendors...
https://www.gearvendors.com/4x4gmmanual.html
Here's a pic of a GV unit I installed in one of my trucks. The transfer case is a NP205, which again, is what your K2500 should have.
72Cheyenne454 is offline   Reply With Quote
Old 02-13-2021, 04:04 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If I could do my K20 over I'd go GV overdrive. I don't have known part numbers to share but believe Yukon Gears (https://www.yukongear.com/) can set you up with the axle pieces you'd need for a gear swap.
Old 02-13-2021, 05:48 PM   #9
a Good Man
a Good Man's Avatar
I don't know how to thank you, I'm still learning here and I'm very lucky with you. Thank you
MY Facebook
Old 02-13-2021, 05:54 PM   #10
57taskforce
All about them K’s
57taskforce's Avatar
That’s a great looking setup.. I’m going to do the same to my K20 when I do my LS swap.
a Good Man, I agree I would go the gear vendors route, by the time you got new gears and install kits, seals etc to swap gears on both axles and got everything installed, you’d probably end up spending more than the gear vendors unit.
Tyler
