Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 02-10-2021, 01:35 AM   #676
57taskforce
All about them K’s
57taskforce's Avatar
Re: What did you do today not on your truck...
I’ve been messing with this 3306 cat for a week or so on and off. I did a full rebuild with all new consumables on it 3-4 years ago and it sat for a year or so before we sent it to the field. Once there it ran great but started loosing oil pressure after a few weeks. We ran it an entire summer before the pressure got low enough we couldn’t run it anymore. I had 2 spares at the time so we swapped another one on and it’s been fine. We used the other spare up right after Christmas so it was time to tear back into this one... I pulled it a good ways down leaving only the head, complete valve train, and rotating assembly in the block. Turns out the oil pressure relief on the then new oil pump was never torqued down at the factory. The bolt backed as far out as the pump housing would permit. Bearings and internals still look brand new. Slapped a reman cat pump in it and start sealing her back up. Just glad it was something simple. Sucky part is that’s just one more part im going to have to inspect going forward. Here it is ready to come off my engine stand. Pardon the mess below. You never can get all the oil out before you pull the pan.
Tyler
Old 02-10-2021, 12:00 PM   #677
1976gmc20
Originally Posted by FleetsidePaul View Post
I paid my taxes. Ouch. I need a write off.
I sent one batch of stuff off to the accountant Monday after waiting a week after the end of January for everything to come in, then the next day another 1099 comes in Screw it, I had the number - let's see if the CPA complains.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 02-10-2021, 12:07 PM   #678
davischevy
Originally Posted by 57taskforce View Post
I’ve been messing with this 3306 cat for a week or so on and off. .
That's quite and engine stand. How did you get into diesel repair Tyler?
davischevy is offline   Reply With Quote
Old 02-10-2021, 12:14 PM   #679
57taskforce
All about them K’s
I do it all. I had the fab shop build that stand 3-4 years ago. Has an 60:1 gear box on it that’s rated for 5 or 6000lbs. Note the oil tank up top. I’ve got a pump below that runs on 12v that I use to prime the galley at 15-20 psi on some of the builds. More and more it seems like I’m the guy that always gets sent to the stuff no one else can figure out or knows how to do. Job security.
I’m getting ready to go fix a water truck as we speak. That particular 06 is actually a t/a natural gas, about 200 hp at sea level. I do most of the more invasive in-house heavy diesel work on our water trucks, rig up trucks, backhoes etc. we have a parts changer truck mechanic that does the maintenance related stuff. I do all the other major engine work that we don’t feel like farming out.
Progress from yesterday afternoon
Tyler
Old 02-10-2021, 12:30 PM   #680
1976gmc20
I was into my Cat engine a couple times. It had the notorious 2-piece piston failure and the first time I tried to save money and didn't replace the other three Both times were out in the woods of course. Second time late in the fall and it was raining. I rigged a tarp over the rack and brush guards, and had my fiance' out there greasing and handing me new bearings while I laid on my back in the mud.
Then later I worked for some folks in the winter doing carpentry and mechanic work, and he had me do a ring and bearing job on one of their D-2s. At least that was in a shop with a wood stove and a log beam to winch the head off and on. But those big cast iron oil pans and the transverse spring are still the worst part.
Don't know if you know this but those old four banger diesels if you didn't change the sleeves the pistons had to go in from the bottom because the rod journal is bigger than the bore! I had to have somebody stick a screwdriver in the wrist pin when it came up and then I crawled out and put on the rings and compressor and tapped it back down into the bore. Fun, fun!
These days I do most of my mechanic work with a check and a pen
Old 02-11-2021, 11:56 PM   #681
allchevy58
allchevy58's Avatar
Just finished replacing propane heater in the shop with a used oil furnace. Fired it up tonight, works great.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 02-12-2021, 10:27 AM   #682
72c20customcamper
72c20customcamper's Avatar
Picked up the rear for my Dodge. I bought it just outside of Wilkes-Barre PA about a five hour round trip . Everything I found around here that was in good shape came at a minimum of 1200. Bought this one for $600 came out of a 70k mile southern truck that got nailed on 81 last fall. Looks like it just had a brake job too . Super clean outside and inside. I also bought some interior items from the donor truck for my truck .
Side note I think the alternator on my Envoy is on it's way out . Volt meter was jumping around and the dash lights were flickering between dim and bright
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 02-13-2021, 02:10 AM   #683
LockDoc
The Older Generation
LockDoc's Avatar
Wifes '05 Buick Rainier was doing that. I took the battery cables off and cleaned them good, tightened them back up and it cured it. Worth a try.
LockDoc
Leon
Old 02-13-2021, 09:55 AM   #684
72c20customcamper
LockDoc
I'll give it a try .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-13-2021, 12:37 PM   #685
1976gmc20
LockDoc
Back in the old days about 75% of battery/electric problems were corroded battery cables and loose v-belts.
I don't know how many I cleaned and tightened when I worked at the service station. It was often for free for the folks who bought gas there all the time.
Old 02-13-2021, 03:45 PM   #686
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do today not on your truck...
Doing brakes & bushings on customer golf cart. If you want to go fast you have to stop even faster.
Golf cart brakes, bushings and labor $325.00.
New shoes are $26.00 each x 4
New hub's $49.00 each
Bushing kits $24.00 for both.
Total in parts = $226.00
$99.00 labor for about 6 hrs work. That's $16.00 hr labor.
I love working on these!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-13-2021, 05:13 PM   #687
72c20customcamper
Picked up 200 ft of CDL blue tubing to run my maple taps to a 150 gallon tank . Just from the 6 big sugar maples I tap ,about 35 trees now
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-13-2021, 06:12 PM   #688
57taskforce
All about them K’s
I feel for you, Few things suck more than having to do them in frame, even in a shop it sucks. I’m sure having to stab the pistons from the bottom and not kill the new rings or mar the rod or crank journals is a lot of headache. I’ve never had the pleasure of knocking them in from the bottom. (Insert that’s what she said joke here)
Tyler
Old 02-13-2021, 06:24 PM   #689
72c20customcamper
LockDoc
Not the problem cleaned everything . Think the internal regulatory is going I hooked up my fluke meter at startup its 12.4 volt then jumps to 14.2 and just jumps around going from 12 to 16 volts . Battery is at 12.9 at rest ,time for a new alternator. Buying a new Acdelco not a rebuilt
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-13-2021, 06:46 PM   #690
1976gmc20
You have to leave the rings off until you get the piston poked up above the bore. That's why you need a second person to catch them and stick a screwdriver or something into the hollow wrist pin to hold it up.
Those ole four banger blocks were huge, though. Lots of room beside the crank, though you had to turn the rod journal to one side for each cylinder.
I heard some old guys compressed the rings from the bottom but seems too hard for me.
Old 02-13-2021, 06:54 PM   #691
LONGHAIR
Originally Posted by Black_Sheep View Post
I took the training class to renew my CCW permit. Good for another 5 years...
You have to take a class for that? I renewed mine in the summer of '18, nothing but fill out a few papers, a new photo, and of course some $$$
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-13-2021, 07:06 PM   #692
1976gmc20
Looks like we're (finally) going to get "constitutional carry" in Montana
Old 02-13-2021, 07:23 PM   #693
davischevy
My CC renews in August. Arkansas charges $52.50 for a 5 year permit, and we have to take a 1-2 hour class.
Old 02-13-2021, 07:27 PM   #694
57taskforce
All about them K’s
We have to take a class and shoot to get be permit and renew...
Tyler
Old 02-13-2021, 08:15 PM   #695
72c20customcamper
Wow ,NY carry is lifetime no renewal my hr218 I have to qualify every year my 218 is a federal I can have a sidearm In every state and possession of the US
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-13-2021, 08:48 PM   #696
Boog
laying low
Boog's Avatar
I never did get around to doing the permit thing.
Sure does vary by state doesn't it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-13-2021, 08:53 PM   #697
57taskforce
All about them K’s
Nice thing about here is that your car is considered an extension of your home so you don’t have to have a permit to carry concealed in your vehicle. I still have one to carry most everywhere else though.
Tyler
Old 02-13-2021, 08:55 PM   #698
davischevy
Arkansas has a law that says you are not required to have a permit to CC if you are "on a journey".
That pretty much leaves it up to the situation and the officer.
Old 02-13-2021, 09:32 PM   #699
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
my California permit expired. Now I'm waiting for an appointment to requaulify. I've been waiting 6 months. Another reason to leave this god forsaken state!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-13-2021, 09:35 PM   #700
1976gmc20
I mostly open carry.
But in the wintertime, well ....
