fender difference between light and medium duty
looking at a set of medium duty fenders.
how much diff is there between the pickup fender and medium duty fenders? I'm considering them hoping it is just larger and wider at tire opening. also fitment to hood and radiator support? I know they will match the cab but other than that what makes them different??? |
Re: fender difference between light and medium duty
depends. you should really add the year and make of your truck in your signature
55-59 chevy/gmc trucks have the same cab in all but the coe model 3100 to 3800 have the same cab, fenders, grill, doors, every but frame and suspension 58-59 viking trucks were the medium duty trucks up to 2 ton the cabs were the same. fenders, hood, grill were wider with bigger wheel openings hard to tell but the fenders are 2" wider on each side 58-59 spartan trucks were the heavy duty otr haulers the cabs were the same. fenders, hood, grill were wider with bigger wheel openings same as viking viking ![]() spartan you also had the coe version, like buggy, if you've been here a while
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 02-04-2021 at 11:19 PM. |
55.2 to 57
Sorry forgot to say that. |
same, chevy just didn't have the cool names
APACHE, VIKING and SPARTAN manly names, not like the 55.5-57 ![]() truck, medium truck and heavy duty truck ![]() ![]()
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
you've been here long enough
really ought not have to ask you the year, make and model of your truck
and now i see you have a 3/4t gmc
i'll be honest, no idea, not familiar with gmc they don't have cool names either
gmc or chevy doesnt matter. fenders are same
![]() Join Date: Mar 2012
There are *many* subtle differences between fenders across the years and makes. From 55-57 Chevrolet lists five different part numbers for fenders for each side of the vehicle. Here's their breakdown:
Chevrolet: 1955-1956 all except Forward Control 1955 Forward Control and 1956-57 FC except series 4,5,6 1957 Series "3" (3100, 3200, etc) 1957 Series "4,5,6" 1956-1957 Series "4-6" Forward Control Folks on other boards say the front axle was moved 2 1/2" forward on the series 4,5,6 "Non-LCF" trucks causing the wheel well opening to be moved about 1" forward. GMC fenders have some differences from Chevrolet fenders but IIRC they are minor and have to do with holes for grille and light mounts. I tried looking parts up in the GMC catalog but it requires a bit more practice than the Chevy book. |
how much difference are you looking to gain? are you talking about going to a larger tire diameter or a wider stance or both?
#11 | |
And just for info. other than the fender emblem holes. the 55, 56 and 57 gmc fenders are the same as the 57 chevy in the pickups. the gmc grill needs the dimple and hole that the 57 chevy uses. and the gmc fenders have the chevy marker light holes but they are not used and are hidden behind the gmc grill and the grill actually holds the marker lights. |
#12 | |||
lots of searching to find out,
no reproduction gmc fenders made, but the dimple on 57 only chevy truck makes them the same as the 55 56 and 57 gmc. so actually if you order a 57 chevy truck repo fender it will fit a 55 56 and 57 gmc other than emblem holes are different and the 55 gmc will need a few holes for lower piece of the grill "mustache" drilled below where the chevy marker light would be. but the actual stamping is the same. Reason I was asking about fenders is I can get a set of medium duty ones that only look from pictures to have a larger cutout for tire and a wider lip around the opening. if thats the case and my pickup hood will match it, I think they will fit better with my wider wheel to wheel measurements and going up to a 17 or 18" wheel. |
#14 | |
Yes your hood will fit. I mention that in my 1st post. Had you read it
#15 | |
I asked a broad question about the general difference between medium and light duty fenders ignoring the stupid little trim hole differences which make no difference whatsoever. I merely was looking for a " they are not even close " or " they are basically the same except for a few inches wider and larger cutout for tire" to which my question was answered. Dont remember being indignant until now. |
#16 | ||
#17 |
![]() Join Date: Sep 2011
Fenders are taller and wider on the Series 4 5 and 6 (1 1/2 - 2 Ton ) than the series 3 pickup version . Hoods are also longer. Plus the front area that meets the grille supports is a different shape and will not match to the pickup. I just cut a big truck fender to grill support area to a guy that is converting a 55-57 Chevy pickup to the big truck grille . He is using pickup fenders with the big truck (boob style grille ) . Also have to convert the upper grille cross bar. I have never checked the actual wheel center opening of a 1/2 ton verses 1 1/2 ton. I will do that sometime a if you were building a 4 x 4 with large tires that would be a nice setup to use. Good luck .
#18 | |
could have sworn hood part number was same for both. will look again tonight. at least on 55 and 56 and same goes for both on 57 |
#19 | |
#20 |
jmloar . I edited my post and added a little more information. Pretty sure the hoods are the same. I was just working with a 47-54 buyer and that year of hood is definetly different . But prettys sure the 55-57 pickup and big truck hoods are the same . Totally different fender as stated above. It really gets tricky when you get into the low cab forward as there are a bunch of different ones there. Good luck
#21 |
that is exactly the info I was looking for.
Thanks |
#22 |
![]() ![]() Join Date: Nov 2008
Ogre's too nice to tell you that THIS reply ^^^ was an asshole comment. We're not like that here and you should know that by now.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#23 |
We're not like that here and you should know that by now.[/QUOTE]
Shouldn't have said I was being indignant when I was just trying to understand what was being said. I got responses and simply responded to info I was given trying to understand the answers and clarify my question. Thats the biggest problem with forums. Its hard to understand the meaning of a conversation without the tones and body language of face to face conversation and when something "seems" what it isn't everyone jumps right to the bad conclusion. instead of asking for clarification. |
#24 |
![]() ![]() Join Date: Oct 2014
Ok, fellas. Let's stay on topic.
#25 |
Got my answer.
Thanks for the help. |
| Bookmarks |
