Old 07-13-2018, 09:20 AM   #1
cochino12
It followed me home?
cochino12's Avatar
What is needed for 22" on dually
What needs to be done to clear 22" wheels on a dually? Everything I read says a standard 22" "semi" wheel will be too wide to clear stock rear fenders. I know Tennessee wheel tires makes a townasty wheel that is supposed to clear but damn they really only come in one style. I know that wider fenders are available but a lot of truck I see out there have original paint. Are all of the trucks I see on instagram.. using a narrowed axle?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-13-2018, 09:53 AM   #2
SCOTI
SCOTI's Avatar
Re: What is needed for 22" on dually
C&C rear ends are narrower & allow using the milled 22's.
The Tow Nastys allow using 22's @ the outer wheel position w/factory 16's @ the inner position on a stock width dually rear end & are supposed to fit under the fender lip (the disclaimer is that all set-ups are different so there is no absolute). As you noted, they only come in one style.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 07-13-2018, 10:10 AM   #3
cochino12
cochino12's Avatar
Thats what I originally thought about the C&C rear but Trevor @ TWNT told me I would have issues with the wheels hitting the leaf springs. So you think all of these trucks I'm seeing are using a C&C axle or narrowed stock axle?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-13-2018, 10:20 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I think most are swapping to a c20 suburban or truck rearend.
Check out @lowboymotorsports on Instagram.
He's done a bunch of these and has good pics.
Under bed c-notch, flip kit and relocated rear shocks.
I believe they also "face" both rear wheels to lessen the overall width.
Keith
Convert to disc brakes.
Old 07-13-2018, 10:51 AM   #5
SCOTI
SCOTI's Avatar
From what I found, the difference in the C20 rear end is the hub assembly & the rear ends are the same width. Apparently the dual rear hub assembly tucks the wheels more than the single (from what I read). And yes, facing the wheels helps keeping things tucked under the OE width dually fender.
Also check w/site member 75dually. He actually did the swap on his square.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-13-2018, 01:06 PM   #6
lolife99
lolife99's Avatar
I actually told you to look at the wrong guy.
Check out @michaelstruckworks on instagram.
I’m sure you could also contact them with questions.
Keith
Old 07-13-2018, 01:12 PM   #7
lolife99
lolife99's Avatar
I believe @lowboymotorsports uses a modified “flat face” wheels in some applications
Keith
Old 02-17-2021, 01:15 PM   #8
Ford Assassin
Ford Assassin's Avatar
Bump...
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 02-17-2021, 10:25 PM   #9
EricU
A standard Dually (DRW) rear end is about 72" WMS to WMS (Wheel Mounting Surface)
A single rear wheel (SRW) one-ton 14b full floater rear end is about 67.5" WMS to WMS which gives you about a 2" tuck on each side.
A C&C rear end is about 63.5" WMS to WMS - I have been told that a C&C will work without a lot of frame work and I have been told that it wont - so that's not much help!
The SRW have an Outboard style hub and the C&C and Dually rear ends have the Inboard style hub - and I still am not sure what those are!!
SWR and C&C rear ends use the same housing, but different hubs, a C&C rear is a SWR housing with dually hubs.
The Suburban 3/4 ton semi-floater rear ends have different spring perch dimensions but you would usually end up cutting those off anyways with a drop kit.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 02-17-2021, 10:27 PM   #10
Ford Assassin
Question Re: What is needed for 22" on dually
How to make it work with DRW AND still tuck under the rear fenders? Flat face rim on the outside rear?
Cable
Old 02-18-2021, 10:28 AM   #11
v30crewcab
v30crewcab's Avatar
a c&c rear works with 16"duallys without hitting the springs. the only problem is the wheel well edge will have to be moved in so the wheel doesn't hit it. I ran a c&c rear with duallys on my 4x4 awhile and it tucked the duallys under a standard bed. but If I had been low, the inner wheel would have hit the wheel well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-18-2021, 10:43 AM   #12
Ford Assassin
I guess I should have been more specific....
How does one make it work with standard, NOT C&C rear end, DRW AND still tuck under the rear fenders? Flat face rim on the outside rear?
Cable
Old 02-18-2021, 10:55 AM   #13
SCOTI
SCOTI's Avatar
Correct. Flat face or milling as needed..... https://lowboymotorsports.com/
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
