Old 02-05-2021, 08:32 AM   #1
Pampas56
Radiator options
After 3 years of puttering, I finally fired off my 89 K2500 ECLB for the first time.
Open exhaust, trans cross member set in loose, a bunch of work to do underneath, and the grill and lights to re-install.
BUT IT RUNS AND MOVES!!!!!
Now for the bad news. The radiator is leaking trans fluid, so a new rad is in my future.
What is the thickest 28 inch radiator that these trucks came with? I have one a little over 1 inch thick and another (the leaker) about 1 1/4 thick.
Is that about it or were there thicker ones available.
Mine will need the trans cooler, but not the oil cooler.
Steve
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 02-05-2021, 09:52 AM   #2
Re: Radiator options
I always got my replacements from Orielly's and no issues. I believe 1 1/4 is the thickest for the 28" wide radiator. At least that is what their website says. You could probably get thicker with aftermarket aluminum, but if you have good fan shroud and clutch fan, that should work just fine.
Old 02-05-2021, 08:35 PM   #3
Tom
driving is in my blood
Tom's Avatar
I put the bigger factory option radiator in my 98 and it won't even hit 220* in rush hour traffic in 118* heat on blacktop with the ac going. Can't see the point of a bigger one unless you are building up a high HP engine.
Old 02-06-2021, 11:27 AM   #4
Snarl95
Snarl95's Avatar
https://www.championradiators.com/Ch...ator-1988-1994
1995 k3500 cclb srw 6.5 turbo diesel.
The lessons that hurt are the lessons that teach.
There is always a price to pay.
You are free to make any decision you want. You are not free from the consequences.
Snarl95 is offline   Reply With Quote
Old 02-07-2021, 11:58 AM   #5
Redneck Rydes
Redneck Rydes's Avatar
X2 on the Champion,I have used a few of these,never had a problem
Redneck Rydes is offline   Reply With Quote
Old 02-10-2021, 12:18 PM   #6
TheChad
TheChad's Avatar
I'm gonna be running a Ron Davis Radiator on my dually.
1993 C3500 BigHips- http://67-72chevytrucks.com/vboard/s...d.php?t=571877
Instagram: duallynotedbighips
TheChad is offline   Reply With Quote
Old 02-19-2021, 03:47 PM   #7
Russell Ashley
Russell Ashley's Avatar
I replaced the radiator in my 96 Z71 recently. I looked at the NAPA website and they had two listed, a standard duty and a heavy duty version. It gives the measurements for the core thickness. I got the heavy duty one like my truck came with originally and the price was $148.79. I have been ordering my parts from NAPA lately and pick them up in the store and they have them ready. With hoses, clamps, oil cooler lines, adapters, and two gallons of DexCool total cost was $320. Convenient if you have a NAPA store near you.
Russell Ashley is offline   Reply With Quote
Old 02-19-2021, 06:08 PM   #8
68 TT
Still plays with trucks
68 TT's Avatar
There is also a taller version of it as well but it requires a different upper radiator support bracket set and matching upper fan shroud/top cover to go with it.
Most likely it is listed as a heavy duty cooling option or is included with certain combinations of HD options and the HD cooling option. The one I have in my 89 C1500 came out of my 94 K2500 ECLB 454 4L80E parts truck. The truck had a camper special option on the SPID so that may be what triggered the taller version.
It is probably an inch taller than the typical version.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
