Old 02-12-2021, 01:59 AM   #26
BAM55
BAM55's Avatar
Re: Electric Fan Setup
Originally Posted by 62 Barnfind View Post
What brand is that radiator?
I had it custom made at Ricks Radiators in Azusa, CA
BAM55 is offline   Reply With Quote
Old 02-12-2021, 09:24 AM   #27
62 Barnfind
62 Barnfind's Avatar
Thanks!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 02-14-2021, 11:10 PM   #28
BIGglaSS
BIGglaSS's Avatar
I did the Volvo fan with a gen1 Camaro LS swap radiator. There was nothing easy about this project. It took about 4 attempts to make everything fit. There is no need to get the Volvo relays. You can wire your own with 2 Bosch relays. I bought a 6 relay box for the LS harness, the fan relays go in there. I haven't got the truck running yet, so I can't comment on whether or not it works
Wiring the fan:
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 02-15-2021, 10:31 PM   #29
_Ogre
_Ogre's Avatar
Very nice!
shop air compressor timer
Old 02-16-2021, 10:58 PM   #30
56 3100
56 3100's Avatar
good to know bigglass on volvo. hope i have the room when i sit engine in mine.
56 3100 is offline   Reply With Quote
Old 02-17-2021, 01:47 PM   #31
jwhotrod
I am curious as to what signals the relays to go high or low speed?
jwhotrod is offline   Reply With Quote
Old 02-17-2021, 09:19 PM   #32
Black_Sheep
Black_Sheep's Avatar
The PCM outputs, determined by parameters in the software. The coolant temp sensor is “read” by the computer, software settings can tailor what temps the fans go on and off.
Black_Sheep is offline   Reply With Quote
Old 02-18-2021, 12:41 PM   #33
jwhotrod
are you using a GM ecu or something aftermarket like a Holley HP, etc.
Thanks for the response.
Old 02-18-2021, 03:45 PM   #34
lv2tri2
Big Glass, your work bench looks like it might have been a bowling alley at one time?
lv2tri2 is offline   Reply With Quote
Old 02-19-2021, 11:18 PM   #35
G&R's57GMC
G&R's57GMC's Avatar
Here's a less expensive option , 2002 Camero rad and cooling fans .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 02-20-2021, 10:52 AM   #36
57FleetsideC4
Lots of great information guys. I will have many choices when the time comes. I plan on using the fan 1 fan 2 out puts from the ecm to control the fans. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-21-2021, 10:16 PM   #37
BIGglaSS
BIGglaSS's Avatar
Yep!
