Old 02-15-2021, 04:03 PM   #1801
pjmoreland
pjmoreland's Avatar
Re: What did you do to your truck today.The 3rd chapter
Spent most of the weekend helping my son replace the timing belt on his Impreza. I had some time while he was at work on Saturday to weld up a speaker hole in my passenger door.
pjmoreland is offline   Reply With Quote
Old 02-15-2021, 10:25 PM   #1802
allchevy58
allchevy58's Avatar
Originally Posted by Barnfind46 View Post
That bed looks amazing. Tell him I am a seasoned auto body guy and I like it!
Thank You, I'll tell him. He used to own a body shop, has done body and paint since high school and just enjoys it in his spare time. He told me he would do it if I didn't give him a timeline.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 02-15-2021, 10:27 PM   #1803
allchevy58
allchevy58's Avatar
Originally Posted by Ol Blue K20 View Post
It looks very nice!
Thank You, I'm liking it too. Can't wait to see it put together. I'll be doing that.
Old 02-19-2021, 01:49 PM   #1804
72c20customcamper
72c20customcamper's Avatar
Got a new clutch fan for the 72 . Come to the conclusion the old one is engage all the time .
Hayden 2705 made in USA
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-19-2021, 05:36 PM   #1805
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
I ordered my e-trac tie downs for the Ramp truck. I got six mounts and straps and rings to install on the sides to tie down the loads.
Plan is to drill and tap the sides to mount the singles to the bed rails.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2021, 11:09 PM   #1806
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice! Any idea as to what the weight rating is per unit?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Last edited by Ol Blue K20; 02-19-2021 at 11:10 PM. Reason: rephrase to avoid being an idiot
Ol Blue K20 is online now   Reply With Quote
Old 02-20-2021, 11:12 AM   #1807
Peanut74
Well I put my spark plug boot protectors on and worked on my fuel filler neck. The boots where a pain as they are 90 degree boots which makes putting the protectors a pain. After the first one I came up with a better way to do it. Used a wooden dowel to guide the boot through the protector. Once I did it this way the other seven were done in the time of the first one. Hope the filler neck goes this easy once the hoses arrive.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 02-20-2021, 11:17 AM   #1808
72c20customcamper
I have them in my enclosed trailer except I have the full tracks front to back.one each side and one in the middle. Use them to trailer the bikes south in winter .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2021, 11:20 AM   #1809
Andy4639
Old member
Andy4639's Avatar
Depending on which ones you buy. I have the 1000lbs working load per each one and 4000 breaking for these. These will only be used for the golf carts and bikes.
I will have grade 8 bolts to attach the clips to the truck with.
Old 02-20-2021, 11:24 AM   #1810
72c20customcamper
I used lots of grade 5 bolts and went thru the steel crossbars in the floor .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-20-2021, 09:52 PM   #1811
allchevy58
allchevy58's Avatar
My friend got the roof and Jams painted.
Old 02-20-2021, 09:55 PM   #1812
72c20customcamper
Started a little project for the 72 .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-21-2021, 12:20 PM   #1813
Ol Blue K20
Nice!
Dale
Old 02-21-2021, 11:32 PM   #1814
allchevy58
allchevy58's Avatar
Nice!
Thank You.
Old 02-22-2021, 09:46 AM   #1815
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Changed the starter with a ACDelco from Rock Auto and worked on finding oil leaks as I was getting quite a few drips just sitting in the garage in idle. After getting transmission leaks fixed it was much easier to just see the oil.
I bought some Tracer Products Engine Oil dye and a uvBeast 365nm MINI - Black Light UV Flashlight. Man, that made things easier!
1. The valve covers bolts were all loose, I could likely almost have been able to remove them by hand. Used a driver to hand tighten the bolts (not a ratchet). I've read these need to be checked after re-installing the covers with a cork gasket. I'd think the shop that replaced my valve seals would have not left them loose but they didn't say anything about checking the bolts after some time either.
2. On the old pan the larger bolts were loose, to me it just seems like my brother forgot to tighten them down when switching between oil bolt sizes. The dye clearly showed oil around the bolt heads - especially on the back by the starter.
So I went from quite a few drips of oil dripping just idling in place to no drips in a 30 minute idle test. Then after my test drive I dropped two dots of oil when I got back. Likely seeping coming around the oil pain at the main bearing area (at the peak of the curve it seems). I did tighten the diver side back oil pan bolt just a bit more too after all that too. The bolt head had some new oil on it (passenger side didn't). I don't think it is the main seal itself - there is no oil anywhere except for a straight down drip from the old pan. There is no oil on the torque converter/flex plate, it is dry as a bone.
I tested / drove without the cover as that darn cover hides the source, so that helped too.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 02-22-2021, 09:58 AM   #1816
67C10Step
67C10Step's Avatar
This may be sacrilege but I worked yesterday on converting my old oil bath breather to accept a traditional air filter element. Like it for the classic look but want something a bit less hassle. Thus far I have gotten all the old element cut out of the top cover and am grinding/sanding it smooth. Will clean it up, paint it, and determine what size WIX filter will work and be off to the races.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-22-2021, 02:29 PM   #1817
Andy4639
Old member
Andy4639's Avatar
I had the tracks in my trailer also when I had it. This is for the Ramp truck flat bed. It has 3/8" tube steel sides so I plan to drill and tap the the top and screw them in. This will only be for the golf carts & bicycles. Just to strap them down.
Old 02-22-2021, 05:26 PM   #1818
72c20customcamper
Made some headway on the console. Holes for cups are done as is the cubby . I’ll make the box for the cubby tomorrow . I made the hole the same size as a din radio so I can add it later if I decide to go that way. Vinyl isn’t glued down was just checking the hole size for the cup holders . Next I need to add the USB ports still waiting on them. Also adding a 30 amp power port
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-22-2021, 06:24 PM   #1819
ChevyGuyNC
ChevyGuyNC's Avatar
Installed a new heater control valve, plus reconnected with new heater hoses. Prior owner had bypassed heater core.
Not pictured, new fuel filter, cap, rotor and coil. Next up points/condenser, and plug wires.
Found I had separate point and condenser and ordered a combo set. That'll teach me to order without looking first... lol
Oh and the preheat tube from exhaust manifold to air cleaner.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 02-22-2021, 06:58 PM   #1820
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
How you plan on mounting it in the truck? I've been thinking about doing one of these my self for the Ramp truck and build it around the floor shifter.
Looks good by the way.
Old 02-22-2021, 07:11 PM   #1821
72c20customcamper
Just a couple of screws into the tunnel .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 02-23-2021, 06:12 AM   #1822
Ol Blue K20
Looks good, want to see it covered....
Dale
Old 02-23-2021, 01:31 PM   #1823
Ken O.
I guess this fits in the "What did I do today" category. I drove the 67 GMC into work today since it's been a couple weeks. The speedometer on that truck has never liked the cold and makes some godawful screechy noises on the highway til it usually warms up and quiets down. This morning it decided to make even louder noises which I didn't think possible, the needle was whipping between 40 and 80mph before the needle broke off the base, then the base where it attached to the speedometer flew off and the screech got even LOUDER! So I did the only thing I could and went faster! Haha! It took a minute or two of this ridiculously loud howling but it finally blew something apart inside and all was quiet again. Sigh... I was actually glad cause now I know what to replace. hehe. I never knew a speedometer could make that loud of a racket. Exciting start to the day.
Ken O. is offline   Reply With Quote
Old 02-24-2021, 02:54 PM   #1824
Smitty
Smitty's Avatar
Brought the old girl home after the transplant.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 02-24-2021, 03:09 PM   #1825
pjmoreland
pjmoreland's Avatar
Very nice! I'll be you're excited. I know I would be. What is that silver thing at the top front center of the engine right in front of your thermostat?
