Old 02-23-2021, 07:17 PM   #1
Railroadman
Railroadman's Avatar
RANT - aftermarket parts that are not the same
It's beyond frustrating when you order parts and what you get is not what you need. I've been stalled without progress for weeks while parts come and go back. Here's the latest issue (we're talking a '66 3/4 ton):
Upper control arm shaft, I decided to replace the end nuts or bushings, depending on what you name them. Looked several places and finally ordered the entire assembly - shaft, 2 end nuts, 2 rubber seals or grommets, and 2 Zerks. Now the catalog shows 1/2 ton and 3/4 ton are different and I DID order for 3/4 ton.
I believe what they sent will work but they are NOT exact replacements. Yes, made in China but the real issue is that whoever specced them didn't follow original, or if China modified them somebody should have sent them back. Probably not a high-volume part, but if you're going to have something made, why the hell not make it RIGHT???
Pic #1, top view. No arrows needed, it's obvious they are different. the holes seem OK, it's only the camera angle that makes them look "off".
Name:  Upper control arm shaft comparison - 1.jpg
Pic #2, side view. The dish for the spacer is noticeably more shallow on the new one (yellow arrows). And the overall thickness is less (red arrows).
Name:  Upper control arm shaft comparison - 2 - Copy.jpg
Pic #3 shows the threaded ends are smaller ( by roughly .2") on the new one.
Name:  Upper control arm shaft comparison - 3.jpg
The problem with the original bushings is wear spots on the threads. I can probably dress them up with a triangle file, use new rubber grommets, and keep everything original although I'm not crazy about the wear.
Name:  Upper control arm shaft comparison - 4.jpg
The box shows part numbers for M00G, McQN, TRW and Spicer. So I'm guessing it's pretty much the only game in town no matter which final vendor you order from.
It's not only trucks, this issue has come up with other restorations. Not everybody is going for judging and perfection, mine will just be for driving and cruising. But as long as a manufacturer is going to have a replacement part made, I think most of us would be glad to pay a couple dollars more to have something identical to what GM made to start with!
Railroadman is offline   Reply With Quote
Old 02-23-2021, 08:03 PM   #2
PGSigns
PGSigns's Avatar
Re: RANT - aftermarket parts that are not the same
Parts are a crap shoot anymore. I did rear sway bar links on a trailblazer today. Same manufacturer same series of parts. Right side was heaver duty with grease able ends, left side was lighter built and non grease able. Just never know what you will get. I just hope it fits when the drop em off.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-23-2021, 08:33 PM   #3
nsb29
nsb29's Avatar
I know the feeling Name:  C9ED85DB-47E8-4C28-BE3C-0127959AAE0E.jpg
They can’t even make both parts the same LMAO
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 02-23-2021, 08:43 PM   #4
Riverstory
Riverstory's Avatar
I feel your pain. Maxwell Smart said it best . . . . missed it by that much!
Riverstory is offline   Reply With Quote
Old 02-23-2021, 09:18 PM   #5
Railroadman
"Would you believe...."
Sometimes it's not a big deal, sometimes what they send is totally useless.
Old 02-23-2021, 09:52 PM   #6
66C10LB
It's bad enough that most body sheet metal is not accurate, but worse if suspension parts are that far off. I think that I will order through my local Napa auto parts store so that at least these suspension or steering parts can be easily returned if necessary.
66C10LB is offline   Reply With Quote
Old 02-23-2021, 11:08 PM   #7
chtr65
Railroadman, I believe I have NOS bushings here. You may have them if you pay for the shipping costs. If interested I will have to dig them out. I can send photos if you are interested. Sorry to hear that you are a victim of the new norm. Let me know if I can help.
chtr65 is offline   Reply With Quote
Old 02-23-2021, 11:50 PM   #8
Railroadman
Thank you very much - that is a kind offer!
I did some preliminary cleaning and prep work tonight and think I may use the new assemblies. Will get back on it either tomorrow, or later in the week. I'll post back here when I figure which way I'm going. It would have been ideal if parts were interchangeable from one to the other, but as you say these days that's just not apt to happen.
Old 02-24-2021, 11:22 AM   #9
roll_the_dice
roll_the_dice's Avatar
New parts are definitely a crap shoot...I cringe everytime I try to replace a structural OEM part...hoping I win the parts lottery, but most times I don't!
roll_the_dice is offline   Reply With Quote
