#15 |
Re: gear box ripping out
That level of damage i would buy both the weld on repair kit and bolt in brace kit .
Fix the frame first . Stop drill all the cracks . Then bolt the repair plate on nice and tight via the 4 holes the box bolts on with . Stitch weld it like the directions show . Then bolt on the box and brace kit . With the weld on repair kit and bolt on brace kit you might need longer bolts for the whole sandwich . And make sure you get a bolt in brace for 2wd . As there didferent over 4wd .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
| Bookmarks |
