Old 03-01-2021, 02:22 AM   #1
Awann99
Stock quiet muffler recommendation.
I’ve grown tired of the droning from my turbo mufflers so I want to put something quiet on the truck that will give it that original tinny sound. I have the old exhaust cut off from transmission work so I have the opportunity to run a original single exhaust. Would I see a major difference is gas mileage after running a single? I believe the pipes my local exhaust man uses are 2.5 inches. Any suggestions for mufflers. I was thinking of going with a universal walker 17911.
The truck is running a crate goodwrench 350 195/235 hp,SP2P intake( Yes I know it’s ancient lol) Rebuilt Quadrajet from national carburetors, HEI, sm465, factory open 3.07 gears.
Awann99 is offline   Reply With Quote
Old 03-01-2021, 07:17 AM   #2
notsolo
notsolo's Avatar
Re: Stock quiet muffler recommendation.
IMO size of the pipe adds to the noise, OEM pipes would have been closer to 2 ". I don't think there is much difference in mpg. Big Cadillac muffler would be quiet . I have seen a stainless kit, about $800. Y pipe back in an OEM style. If you go with 2 1/2" add a resonator or 2nd muffler it will help a lot...
notsolo is offline   Reply With Quote
Old 03-01-2021, 11:18 AM   #3
Sheepdip
Sheepdip's Avatar
I second the Caddy Mufflers
Sheepdip is offline   Reply With Quote
Old 03-01-2021, 11:49 AM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Vote #3 for the Cadillac muffler(s). Single or dual. One of them muffles a 500 CI engine, so it would not hurt a 350. Also, 2-1/2" pipes are OK, but unless you have manifolds with that size outlet, they don't help all that much. I had a '64 Impala with 2-1/2" outlets, but the tail pipes were 1-3/4", IIRC.
~Steven
Simi Valley, CA
Old 03-01-2021, 12:27 PM   #5
MikeB
MikeB's Avatar
I would not go from duals to single unless you can live with less power and poorer fuel mileage. Worst case I would buy some basic stock replacement Walker mufflers and keep the duals. Even then you will lose some efficiency due to the mufflers being "necked down" internally. It's called "restriction" and is one way to reduce exhaust noise.
Quick story: Stock 69 C10 with 307 2bbl, single 2" exhaust, OE-type muffler, and 1-7/8" tailpipe. It got 10-12 mpg all around driving. Went to 2" duals with turbo mufflers (that actually weren't too loud) and mileage jumped to 12-14. And I can't begin to describe how much more power the engine had. With stock exhaust, it sounded like it was laboring to maintain 60 mph. With dual exhaust, it was like it got a shot of an asthma inhaler!
I just remembered this: Back in the day, it was common knowledge that a 250hp/327 4bbl with dual exhaust would get better fuel mileage than a 195hp/283 2-bbl with single exhaust. Of course, that was if your right foot behaved responsibly! In addition to the benefits of dual exhausts, the 4bbl primary venturis were smaller than the 2bbl venturis for better efficiency.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-02-2021, 03:29 AM   #6
BRL
BRL's Avatar
I had 2 Flowmasters dumping just behind the cab and that got annoying pretty quick.
Went to a Walt's Muffler shop and my friend's brother installed a 2 1/2" dual exhaust with a balance tube in between, that dumps behind the axle.
(I'm running headers too)
Don't know what kind of mufflers, but the first time I fired it up I had to ask if the motor was running!
BRL is offline   Reply With Quote
Old 03-02-2021, 06:39 AM   #7
Awann99
Lots of good info. Thanks fellas. I think I will stay with the dual exhaust then but add the crossover pipe and use the Cadillac mufflers. It looks like walker makes a few of them.
Old 03-02-2021, 11:23 AM   #8
71longbed-brew
71longbed-brew's Avatar
i went with these when i was tired of my glasspacks
https://www.amazon.com/Walker-18106-...78187676&psc=1
350/th350
Sportsman2 heads
Performer Intake
1406 carb
3.42 Eaton Posi
71longbed-brew is offline   Reply With Quote
Old 03-02-2021, 11:45 AM   #9
MikeB
MikeB's Avatar
FYI, that part number is 2-1/4" in and out.
Mike
Old 03-02-2021, 08:37 PM   #10
jimijam00
2.25 pipe with the longest walker oem replacement case muff you can fit under there.
jimijam00 is offline   Reply With Quote
