#151 |
![]() Join Date: Sep 2003
Re: The build date project
72 chevy
08/71 2F307062 |
#152 |
1970 Chevy C10 short bed found on classic.autotrader
1971 SWB step side: Original NM Forestry truck, then NM Fire truck, and now a ranch truck. |
#153 |
71 K10 longed found on classic.autotrader. 1Z660587
#154 |
All about them K’s
![]() Join Date: Jun 2014
Done. I’ve got some more I need to add from pms but I should have that done tomorrow. Carl, that last one from post 153 was added already on post 122. A for effort though! Keep em coming guys!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#155 |
72 chevy
05/72 2S194130 |
#156 |
This is the SPID from my 1972 GMC Sierra Grande. St. Louis built truck. As soon as I get the truck back in my possession I will look for the blue sticker with build month on it. I'm sure it's there, the truck is very original. S508014
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) Last edited by Gigem; 02-04-2021 at 11:09 PM. |
#157 |
![]() Join Date: Feb 2016
Found on FB:
Early 1970 chevy
1966 Custom Camper -327, 3OTT 1968 Chevrolet K20 - 350, 4 speed 1972 K10 SWB - 400, 3OTT 2003 Corvette Z06 - LS6 350, 405HP 2004 Tahoe LT 2015 Silverado 2500HD - 6.0L V8 |
#158 |
deleted post........
#159 |
72 chevy Blazer
2F182202 6/72 |
#160 |
72 chevy
2B115961 10/19/71 |
#161 |
All about them K’s
Done, done, done! Great work guys!
#162 |
another duplicate...........
#163 |
71 chevy
4/8/71 1Z643246 |
#164 |
Here's mine, just got her a couple weeks ago.
1972 C10, Cheyenne Super 4/1972 No build sheet visible under the seat; suspect it was recovered in past. VIN indicates Flint Assembly Engine stamp is V0411TDJ which indicates Flint 4/11/72 and the correct 350 A true survivor, Texas truck with 46k
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor Last edited by ChevyGuyNC; 02-28-2021 at 12:32 PM. Reason: resizing pics |
#165 |
70 chevy
0J110731 |
#166 |
All about them K’s
Awesome! I’ll try and get them added tonight.
#167 |
How did I get this OLD!
![]() Join Date: Dec 2014
Here is my Oshawa 67. I believe Oshawa trucks had no build sheets. They had a line tag with the RPO codes on them and that’s all. Thanks to GM Canada all the info is available. The last pic is of a 69 GM document that would have come from the factory to the dealer.
https://67-72chevytrucks.com/vboard/...1&d=1614563483 https://67-72chevytrucks.com/vboard/...1&d=1614563574 https://67-72chevytrucks.com/vboard/...1&d=1614563652
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
#168 |
70 chevy
06/70 0S1602xx... Maybe 0S160283 |
#169 |
72 gmc
#170 |
TCE142S508014
December 1971
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
#171 |
All about them K’s
Great work guys, the fruits are starting to come forth. Gigem, great job, that last GMC was in the database, however there was no build month/year. Keep ‘em coming. 402Bowtie was able to use this list to prove a truck as fraudulent in another post as well. This is going to be an awesome resource as it grows!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 03-07-2021 at 01:37 AM. |
#172 |
All of the plants used build sheets. The RPO information alone was not enough information for the operator to select the correct part, especially when there was a proliferation of part numbers within the RPO.
Any area where components were built up remotely and then conveyed to the main line in sequence would require a build sheet: front and rear axle trim, engines, transmissions, seats, front end sheetmetal, tire/wheel assemblies, etc. These are all areas with a lot of proliferation, and therefore not easy to present the material lineside, or - in the case of the seat cushions - a fire hazard (the "cushion room" was always way out in the boonies as a result). The build sheet defined the component that was to be installed, by part number or broadcast code, especially for option driven content where there was some choice as to what part was to be installed, or a remote area where there were no visual clues as to what part should be installed. So - theoretically - you would be able to find a build sheet on the motor somewhere, or above the fuel tank, or anywhere a build sheet was used. There was no thought, guess work, interpretation or latitude on the part of the assembler: they referred to the sheet, selected the component by part number or broadcast code, and put it on. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-07-2021 at 11:29 AM. |
#173 | |
Michael
#174 | |
https://67-72chevytrucks.com/vboard/...1&d=1615179163 https://67-72chevytrucks.com/vboard/attachment.php?attachmentid=2087453&stc=1&d=1615179677[/url] Here is what I found so far on the Oshawa build tags. 1-1/2”x 11” tag with partial VIN and RPO’s The last pic is the code that GM sent out with their document package from their records when I inquired about my truck.
#175 |
Yes - those would be used in addition (as a supplement) to the more familiar build sheet.
Those alone do not have enough detail to build the truck. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
