#26 |
Re: 72 big block truck parting out
Looks good. I will take the mirrors.
#27 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Just the rubber grommets for the lines, not the lines themselves. And the bolts etc that secure the gas tank in place inside the cab, and the pads the tank rests upon please.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#28 |
![]() Join Date: Jun 2010
My paypal is heehawracing@bellsouth.net
Thanks |
#29 |
Thanks |
#30 |
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#31 |
#32 |
#33 |
How much for the 15x8 wheels?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#34 |
#35 |
Are the defrost vents on top of dash saddle in color and are they in good shape? If so, I'll take them.
#36 |
#37 |
![]() Join Date: Apr 2010
How much for the motor mounts?
#38 |
#39 |
#40 |
![]() Join Date: Jan 2021
#41 |
#42 |
#43 |
![]() ![]() Join Date: Feb 2009
Few things I may interested in, if available:
A. Fire arrester and hose B. Engine bay wire clips, including those on the valve cover C. A/C system clips. D. S duct if nice. E. Can be talked into a box of hardware. Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#44 |
#45 |
Carpe manana
Sounds good thanks. Basically after what all is needed to bolt a tank to the cab just like GM did.
#46 |
#47 |
![]() Join Date: Nov 2010
I’d be interested in both ac side vent assemblies sir if available and better photos. I have an ochre dash I want to add ac too. Thanks much
Some progress is better then no progress |
#48 | |
#49 |
Is it crack free in good working order and what would you have for it shipped to 91304. Thanks much
#50 |
Is that ashtray bolted in, or welded in? If it welded, I would be interested in the plastic glides on the dash mount for it.
