03-09-2021, 09:55 PM | #1 |
Re: 1972 c10 body swap t56 AWD ls2 build
4 years later...
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
03-09-2021, 11:56 PM | #2 |
03-10-2021, 12:01 AM | #3 |
Inner rockers are done so far. Lower fender bolt installed
03-10-2021, 07:07 AM | #4 |
Making progress!
71 C10 72 K20 72 K10 Super Kirk |
03-15-2021, 06:43 PM | #5 |
I had a couple hours today and go the core support mounted. I had to do a bunch of measuring to make sure it got in the right spot. Wheel spacing, firewall spacing and room for radiator all look good.
The rest of the cab mounting process will be based of this. I did multiple searches on the internet and found that the front wheel centerline to the core support mounts on a c10 is 21.5 inches. So I measured from the tbss front wheel centerline and that's how I got the location to drill the wholes. I should have taken a pic of my contraption I had set up to get that measurement. It was kind epic/wonkey, but it worked. Once I get the cab tacked in place where it will set, I will set the bed on to make sure it will work and then weld everything in place. |
01-31-2023, 11:29 PM | #6 |
Small photo dump. I've been spending alot of time on the fire wall. Got the flange made and welded in. I got the firewall cut to size. It will be cut and trimmed more. Got my pedals fabbed up. Waiting on the pedal pad rubbers to come in the mail. There is more to be done on the pedal bracket, but I got to get the firewall set in place first. I'm gonna attempt to emboss a design on the firewall by hand. I've gotta get some mdf board and get a design figured out. I was able to cut the temporary cab support out. I figured I was far enough along to do that. I think that's about it for now.
01-31-2023, 11:36 PM | #7 |
More pics
