#1 | |
Re: Will stock hub caps work?
Been looking at Wheelsmith caps, the '49 chev one looks alright;
http://thewheelsmith.net/wheel-acces...ie-accessories They are marketed for smoothie wheels but have to find out if they'll fit 16" wheel vintiques. FYI - steer clear of 16" wheels as there doesn't seem to be much available in terms of tires, caps, etc. I'm sure alot of you likely know that anyway. My own mistake, should have done more research and possible just went with 15" as there seems to be much more available.
“The doctor said I wouldn’t get so many nose bleeds if I kept my finger outta there,” - Ralph Wiggum |
![]() Join Date: Jul 2009
Yes, you are correct. That's why I qualified my comment with the buzz word "like" or similar to the WV 62 series. He needs a wheel with that same nub location and nub size if he wants to use the stock '64 cap regardless of wheel diameter or manufacturer.
Gotcha. One needs a wheel w/the 'nubs' in the correct position or that allow clips to be added in the correct location.
