Old 03-11-2021, 08:33 AM   #1926
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by NewBayColony View Post
Looks great! What color is your truck?
Placer gold which is a car color, special order with the Husky package
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-11-2021, 11:57 AM   #1927
pjmoreland
pjmoreland's Avatar
Got most of my parts back from the body shop yesterday so I started assembly. Removed the old bed fender, installed the bed steps, installed gravel shields, and sprayed undercoating on the replacement fender. Also drilled out the carriage bolts a PO used on the bed fenders and installed stock style screws.
pjmoreland is offline   Reply With Quote
Old 03-11-2021, 12:04 PM   #1928
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking good!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-11-2021, 01:53 PM   #1929
Sam1968 PNW
Sam1968 PNW's Avatar
Got my bedsides ready for blast n paint!
-1968 C20 Conversion Under Construction
-Son Of A 22 Yr Retired USN E-8/Housewife
-Father of 2, Partner To My Love
-23 Yr Ship Repair Welder/Fabricator
-PNW LMB Kayak Fisherman
”IT IS WHAT IT IS, AINT NOTHIN TO IT BUT TO DO IT SON”
Sam1968 PNW is offline   Reply With Quote
Old 03-13-2021, 10:03 PM   #1930
ChevyGuyNC
ChevyGuyNC's Avatar
Got the old girl purring today, thanks to my new friend Eddie. We discovered the timing way off, too far advanced. Back to a factory 8 degrees, and she really smoothed out. Then getting the dwell back to 30, and some carb adjustment. Wow what a difference.
Also found that the mufflers are shot, broken inside and rattling loudly... so off to the muffler shop ASAFP.
Also reconnected the cig lighter, and the AM radio antenna cable. Guess what, the 50 year old stock AM still works!
Got the hood adjusted so it doesn't stick up by the cowl too. So no new hinges needed.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 03-13-2021, 10:44 PM   #1931
NoStopN
NoStopN's Avatar
Yeah ChevyGuy, these radios still work easily. I have the problem of the speaker not being hooked up right by a previous owner.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 03-14-2021, 07:47 PM   #1932
pjmoreland
pjmoreland's Avatar
Installed bed fender and grille. Will be picking up driver door from the body shop on Monday.
Old 03-14-2021, 07:53 PM   #1933
Ol Blue K20
What ya doing with the drivers fender?
Dale
Old 03-14-2021, 08:00 PM   #1934
pjmoreland
pjmoreland's Avatar
That primer one I've got on there is temporary. I got the original one repaired and painted, but I'm going to install it after I install the door since the hinge bolts are a pain to access with the fender in place. I was planning on installing the grille at that same time, but I got impatient.
Old 03-14-2021, 09:52 PM   #1935
Ol Blue K20
Aww, now I understand..
Dale
Old 03-14-2021, 10:11 PM   #1936
Boog
laying low
Boog's Avatar
It's looking good too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-15-2021, 05:30 PM   #1937
ChevyGuyNC
ChevyGuyNC's Avatar
Super happy!! Got new Magnaflow mufflers installed today. The old ones were cheapo's that were blown out. OMG does she sound awesome now!!!
Ran out of time to replace the donut gaskets (manifold bolts are rusted to crap) so I'll go back next week.
If any of y'all are in or near Jacksonville FL, I highly recommend Muffler City. Ron is a C10 guy and really knows these trucks.
Old 03-16-2021, 10:13 PM   #1938
Mac93
Mac93's Avatar
Safe to say when rubber weather stripping has to be chipped out, it's time to be replaced. Also replaced the wing window felt. Thanks to Brothers truck parts youtube tutorial.
Mac93 is offline   Reply With Quote
Old 03-18-2021, 07:52 PM   #1939
72c20customcamper
Going to paint the replacement column for my 72 . Took the shifter arm off but couldn’t get the turn signal stalk off have both new. At one time someone put what looks like JB Weld on the stalk and screw I even tried my 3/8ths impact on it no joy. Don’t want to break it since everything works and is the correct red knob flasher. So disassembly is at a stand still any suggestions to remove the screw ?
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-18-2021, 08:37 PM   #1940
Boog
laying low
Boog's Avatar
Try a little bit of heat but be careful.
Boog
primer is finer
Old 03-18-2021, 08:40 PM   #1941
67C10Step
67C10Step's Avatar
Ordered the bed box for my truck from Mar K today. Wife and I are going to do a day trip next Friday and pick it up at their place in Oklahoma City.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-18-2021, 08:46 PM   #1942
72c20customcamper
Was thinking maybe heat up cheap Phillips head . I do have a NOS correct turn signal switch but don’t want to use it if I don’t have too
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-18-2021, 09:01 PM   #1943
Boog
laying low
Boog's Avatar
I suppose you could drill the screw out but it would be tough getting all of it out deep in the threads. You'd still need to heat that JB Weld to release the lever from it's grip though.
Boog
primer is finer
Old 03-18-2021, 09:26 PM   #1944
BigBird05
Buy the dorman turn signal repair kit (49300). When it arrives you can drill out the screw and save the red emergence flasher knob.
BigBird05 is offline   Reply With Quote
Old 03-18-2021, 10:01 PM   #1945
72c20customcamper
Guess I could cannibalize this one if need be
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-19-2021, 08:06 PM   #1946
cj847
cj847's Avatar
Put 4" rear drop springs in the 71. Front is stock 50 year old springs.
Before and after:
cj847 is offline   Reply With Quote
Old 03-19-2021, 08:28 PM   #1947
Ol Blue K20
Before and after:
Looks good!
Dale
Old 03-19-2021, 09:51 PM   #1948
sfont66
sfont66's Avatar
I Was able to get my frame cut today on the 72 C10. Hopefully tomorrow I will have some time to weld it back together.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 03-20-2021, 07:11 AM   #1949
NewBayColony
NewBayColony's Avatar
Gave mine a couple of black and blue eyes,Name:  BlacknBlue.jpg
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 03-20-2021, 07:23 AM   #1950
Boog
laying low
Boog's Avatar
90 right
Boog
primer is finer
