Old 03-12-2021, 01:45 PM   #1
KoolKraft62
Extended Cabs
I've been collecting parts for a Pro Touring C/10build. I'm 6'4'' I think I'll need to build a extended cab/SWB to fit in. My thoughts are taking 2 cabs combining the them for a door 6'' longer for more leg room. Has this been done before. Dont want a 4 dr truck. Any thoughts or Help would be appreciated.Thanks
KoolKraft62 is offline   Reply With Quote
Old 03-12-2021, 03:21 PM   #2
C101972
[QUOTE=KoolKraft62;8893135]I've been collecting parts for a Pro Touring C/10build. I'm 6'4'' I think I'll need to build a extended cab/SWB to fit in. My thoughts are taking 2 cabs combining the them for a door 6'' longer for more leg room. Has this been done before. Dont want a 4 dr truck. Any thoughts or Help would be appreciated.Thanks[/http://67-72chevytrucks.com/vboard/forumdisplay.php?f=3[/
C101972 is offline   Reply With Quote
Old 03-12-2021, 04:18 PM   #3
RustyBucket
RustyBucket's Avatar
Re: Extended Cabs
Just 1 old guy's opinion... I've liked these trucks since they came out in '67. I'm afraid after the modifications the truck will look out of proportion, even if your fit & finish is as good or better than factory. After looking at this body style for 50yrs. I don't think it's gonna be pleasing to MY eye anyway... might surprise me though. If YOU spend the time & money & it makes YOU happy it's a success. I've seen pictures of late model GM trucks with slant nose front caps that didn't look too bad. I understand the problem with the interior room, I'm only 6' but fat and my GMC isn't comfortable. Shortening the steering column helped some. I've been kinda looking at '88 thru 2000 Chyenne's, roomier inside, clean single headlight front and they don't seem to rust as bad.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 03-12-2021, 05:25 PM   #4
Custom 68
Custom 68's Avatar
Re: Extended Cabs
What you are describing has been done. I will do some diggng to find it (if I can). I think the proportions didn't look out of place. I believe it was a silver truck. I will see what I can find.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-12-2021, 05:51 PM   #5
Custom 68
Custom 68's Avatar
Re: Extended Cabs
http://67-72chevytrucks.com/vboard/s...d.php?t=123621
Wow this was 2004 so I am not sure where the truck might be now. The one I remember is the silver one in this post. Since this has been over 17 years ago I would like to think it has been done a few times since then as well. Lots of neat and useful things being done to these cabs to make them more comfortable.
Dave
Old 03-12-2021, 07:43 PM   #6
truckster
truckster's Avatar
Re: Extended Cabs
If you've got the truck, the tools, and the skill, why not? Looking at the pics Custom 68 posted, I think it would make people do a double-take to figure out what was different from a stock truck.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-12-2021, 09:24 PM   #7
BigBird05
Re: Extended Cabs
I looked into it an looked at the measurements. If you take a lwb frame and put a swb box on it that will give you 12 + or - " to extend your cab. take the back of your cab and most of the roof and move it back. Then you can buy a replacement roof. That was with a standard size door. If you are going to lengthen the door then you would need to move the pillar and it might be better to section the whole cab.
BigBird05 is offline   Reply With Quote
Old 03-12-2021, 10:29 PM   #8
cj847
cj847's Avatar
Re: Extended Cabs
This one was built 20 years ago. Not a bad buy considering the work you are about to do.
https://www.facebook.com/marketplace...code=undefined
cj847 is offline   Reply With Quote
Old 03-12-2021, 10:43 PM   #9
C101972
Re: Extended Cabs
Check out rtech fabrications.
Old 03-13-2021, 01:30 AM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Extended Cabs
I miss my old 72 extended cab, it was the most comfortable to drive of all the trucks I've had. Here's a few pics I saved of one that was extended to the rear of the cab. It would be a lot of work but if you were to split the difference and extend the doors 3" and the rear of cab 3" it would probably be a lot less noticable. You might even be able to sneak in 7 or 8 inches.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-13-2021, 07:45 AM   #11
72 tigger
72 tigger's Avatar
Re: Extended Cabs
I built this in 1996 and sold it 2 years ago. 22” added with a small bench in the back. I did move the front seat back slightly for more legroom
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 03-13-2021, 10:50 AM   #12
KoolKraft62
Re: Extended Cabs
Thanks for the comments. A friend did this photo shop of a cab extended. The cab was lengthened & bed shortened the distance the cab was lengthened.
