Old 03-10-2021, 10:22 PM   #1
cff
Active Member
GMC Engines
I have a 51 GMC half ton pickup with a 228 cu in engine. I would like to put in a 270 or 302 GMC engine. Will either of these two engines bolt right in without any mods?
cff is offline   Reply With Quote
Old 03-10-2021, 10:55 PM   #2
Bimus
Re: GMC Engines
I have a GMC 270 and a military 302 out where I can get pictures I know the exhaust is larger .
Bimus is offline   Reply With Quote
Old 03-11-2021, 01:12 AM   #3
mr48chev
mr48chev's Avatar
Re: GMC Engines
Outside dimensions are the same. just as any change there may be some linkage issues on the carb but none that you can't get past.
No matter what size those GMC engines are they are a bit spendy to build.
My ongoing truck projects:
Old 03-11-2021, 12:22 PM   #4
Bimus
Re: GMC Engines
Both engines are military the 270 is out of a 42 and the 302 [Green ] from a mid 50's it has motor mounts at the front on the sides and I don't know if the military 302 where drilled for a pilot bearing in the end of the crank. trouble with pictures I will try later today
Old 03-11-2021, 09:31 PM   #5
Bimus
Re: GMC Engines
still can't post pictures because security token is missing ?
Old 03-11-2021, 11:01 PM   #6
cff
Active Member
Re: GMC Engines
As long as they are physically the same size and bolt up the same, I would be happy. I don't have a 270 or 302 but I was gonna try to find one or the other. I do have a 292 but I don't think it will bolt right in will it? Anyone know what I have to do to make the 292 bolt in easily? Will the bellhousing bolt up? Thanks, Ron
Old 03-11-2021, 11:05 PM   #7
mr48chev
mr48chev's Avatar
Re: GMC Engines
Upload one at a time. meaning choose one file and upload it, then choose the next file and upload it and repeat until you get them uploaded. I have the same issue and either my computer or my network or both is too slow and it times out if I try to do more than one or two. After you get them uploaded they will post.
You may also have an issue if you are trying to post very high resolution photos. I often shoot at 16 meg so my sunset or mountain photos can be blown up to poster size and forget that when I run out back to take a shot of something for show and tell on here.
Old 03-11-2021, 11:06 PM   #8
mick53
Re: GMC Engines
I think the 292 bell housing is the same as the SBC. Keep in mind the 292 has staggered engine mounts. I don't know GMC engines but the 292 is about 3" longer than the 235 I think.
mick53 is offline   Reply With Quote
Old 03-12-2021, 01:34 AM   #9
Bimus
Re: GMC Engines
Thank you one at a time worked
Old 03-12-2021, 01:43 AM   #10
Bimus
Re: GMC Engines
I have few 235 in pickups and some in the shed and can measure and fit parts if needed '
Old 03-12-2021, 02:52 PM   #11
MtGMC
Re: GMC Engines
Civilian GMC 248/270/302 engines all fit the same bell housing and the “horseshoe” front motor mount and will bolt right in. Military versions of the 270/302 have very different front mounts.
The 270 is not too hard to find, but it will definitely cost more than a SBC rebuild. However, it will definitely be different from the crowd. There are performance upgrades available.
MtGMC is offline   Reply With Quote
Old 03-12-2021, 05:22 PM   #12
mick53
Re: GMC Engines
I have a junk GMC engine in the pile with a 3 speed I have been trying to give away for years. Nobody seems to want it. I think it must not be one people want.
Old 03-12-2021, 11:31 PM   #13
mr48chev
mr48chev's Avatar
Re: GMC Engines
You need a cast iron V8 bellhousing from a 55 to early 70's truck. You also need a 168 tooth V8 flywheel
The water pump gets real close to the radiator on a Chevy but You might have enough room on the GMC As long as your radiator has the GMC mounting bracket positions and not Chevy.
The Mount pads are staggered side to side on a 292.
Passenger side mount is in front of the fuel pump on a 292
Passenger side mount is behind the fuel pump on 194/250
I bought what was probably the last pair of 292 mounts that Chassis engineering Inc sold before they sold out to Heidts. They didn't have the deal made with Heidts when I bought mine and they were selling pieces for pennies on the dollar.
I went out and dug my mounts out of the garage and took some photos. They wouldn't be that hard to duplicate if a person was a good fabricator.
I'll have to make the pieces that weld to the frame to use the Ford Flathead style biscuit mounts with when I get to that point.
Old 03-13-2021, 10:38 AM   #14
mick53
Re: GMC Engines
Here are mine.
Old 03-13-2021, 11:02 PM   #15
mr48chev
mr48chev's Avatar
Re: GMC Engines
Thanks for posting those Mick, I've got them saved for my reference file.
Old 03-14-2021, 09:14 PM   #16
cff
Active Member
Re: GMC Engines
Yeah Thanks. Good info
