Old 03-13-2021, 04:05 PM   #1
chris015
12 bolt to a 10 bolt rearend bolt on swap?
Ok. So lil bro has a 87 "r10" 2wd. It has a 12 bolt 2.73 rear end. We put in a 700r4 and its lazy and lugs all to hell. Will a 10 bolt swap from a 12 bolt without any modifications?
Thanks yall. U saved my ass more then once.
chris015 is offline   Reply With Quote
Old 03-13-2021, 04:19 PM   #2
Re: 12 bolt to a 10 bolt rearend bolt on swap?
I don't think it is a bolt in swap. You'll probably need to change the spring mounts at least. I personally don't know of any 10 bolts that came in the 87 and older trucks, so I don't know what the width differences are (if any). It might be easier to change the rear gears to a 3.23, 3.42 or 3.73 gear.
Palf70Step is online now   Reply With Quote
Old 03-13-2021, 06:07 PM   #3
Myself
Yes, direct swap. The 10 AND 12 bolt came in the 73-87 body style.
Myself is offline   Reply With Quote
Old 03-13-2021, 06:14 PM   #4
sweetk30
sweetk30's Avatar
what ? ? ? ....... 10 bolt rear was as common on 81-up as 12 bolt on 80-older was for 1/2 tons .
basicly direct bolt in IF 2wd to 2wd or 4wd to 4wd . for the lug count and the shock mounts .
brakes are the same pattern so if need be pull the shafts . swap brakes . new axle seals and install and run .
u-joint size might be different and need trick joint .
how did the 87 get the older 12 bolt ?
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-13-2021, 09:54 PM   #5
I did not know that. I have never seen a 10 bolt in any of my squares. Learn new stuff all the time.
Old 03-14-2021, 01:47 AM   #6
79vette
Agreed with this.
I have an 86 K5 that came with a 10 bolt rear (military M1009). I swapped the 12 bolt out of my 82 K5 a couple years ago, and it was a bolt in.
Somewhere between 82-86 the parking brake cable layout changed, so I had to swap the parking rear brake cables on my 82 12 bolt for the later style. And the yoke on the 12 bolt for some reason took a smaller U joint. But the axle definitely bolts up to the springs.
I didnt take a pic of the rear axle coming out, it was too cold... But I promise it did happen.
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread
1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread
1979 Corvette - 350 T5
1977 Jimmy - 350, TH400, NP203
1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck
Scratch built 16' flatbed trailer - thread
79vette is offline   Reply With Quote
Old 03-14-2021, 07:28 AM   #7
mongocanfly
mongocanfly's Avatar
my 86 had a 10bolt
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-15-2021, 12:33 AM   #8
kwmech
Why would you go backwards in strength? Do a gear swap and put in a posi at the same time
Old 03-15-2021, 01:07 AM   #9
79vette
Agreed a gear swap and posi is probably better than swapping in another used axle in unknown condition.
But I don't know if a 10 bolt is backwards in strength. The 8.5" 10 bolt ring gear is 3/8" smaller in diameter, but the small pinion shaft and outer pinion bearing on the 12 bolt brings the suck. I don't think you're gonna break the ring gear, but losing a pinion on the trail would be a pretty bad time.
The only reason I swapped one into my truck is because it already had a selectable locker (ARB) in it.
Old 03-15-2021, 01:39 AM   #10
Just call me Sean
Just call me Sean's Avatar
I put a 10 bolt in place of my 14 bolt. Because money doesn't grow on trees.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
