Who Me?
97 Tahoe 5.7 p1345 code solved
I have had this code for many years and I did some research on it, but didn't resolve it until this past weekend.
I'm not a professional mechanic so I did not know that my cap and rotor issues are directly affected by the P1345 code. I also think my p0430 code was caused by the P1345 issue. I cleared the codes 2 days ago and neither have returned. My theory is when the crank/cam position correlation was off, it was causing the misfire probably putting too much unburned fuel down the exhaust possibly causing the P0430 code (catalytic converter is not functioning efficiently). I was under the impression that the distributor was in a fixed position and a fancy scan tool was required to make any adjustments to solve this issue. Thanks to a guy on you tube, he shows how you can take an old cap and modify it to watch the spark for cyl #5. see below. I took this video as I adjusted it. https://www.youtube.com/watch?v=GYMKenBb6TA Here is a 2nd video of it resolved. https://www.youtube.com/watch?v=h5RgpjPK8wQ This is the video that helped me resolve this issue. He did something different with the dist. hold down bracket that I didnt need to do. Mine had room for adjustment. https://www.youtube.com/watch?v=obP09XSt4Yo&t=386s All feedback is welcome and I hope this helps someone else with this issue. Thanks! Steve
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
| Bookmarks |
