Old 03-15-2021, 09:06 PM   #11
JJH Jimmy
JJH Jimmy's Avatar
Re: Budget Build 1985 K20
About the doors. I got them primed and filler applied and went to start sanding and the epoxy was soft under the filler. So i figured it was due to a couple of things......my shop temp was near the minimum for the epoxy, thickness of the 3 coats of epoxy and applying the filler in 24 hours. I think I would have been fine if I waited a couple days to apply the filler. So I sanded them back down and started over. Lesson learned don’t rush more so if it is cold.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
